[ Total Views: 472 | Total Replies: 1 | Thread Id: 8049 ]
Author: Subject: Dry Sumps !!!!
Memberbugboymatt
A.k.a.: Matt
Threads: 75
posted on July 1st, 2003 at 10:11 PM
Dry Sumps !!!!
Okies another shot in the dark !!!!!
Who's got a dry sump in there bug and is it a worth while mod to do !!!!!!!!
MemberPhil74Camper
Head in the Clouds
Threads: 193
posted on July 3rd, 2003 at 12:02 AM
Rod Young in Sydney dry-sumped his 1835 '69 Beetle back in the mid- 80s. He isn't active in Club Veedub any more so I dunno if he still owns it.
I think he used a Shadek two-stage oil pump (the scavange pump must be higher capacity than the supply pump). He used an ATF tank from a semi-auto Beetle as his oil tank, together with various thermostats, coolers and electric gizmos that I only vaguely remember now. But he could prime his engine oil system prior to startup from the driver's seat. He wrote about ihis mods in our club magazine back in the '80s.
He really knew what he was doing, but it was a hell of a lot of work. As to whether it was worth it - he never raced his Beetle so I dunno.
Memberamazer
kombi pilot
Threads: 308
Mood: Peachy!
posted on July 4th, 2003 at 11:28 AM
It might make you an extra horsepower if the crank doesnt have to slosh through the oil.
Might save you a crank if you are cornering hard enough to lose oil pressure.
Otherwise its not worth the effort.
Memberjakriz
Threads: 46
Mood: 2 headed
posted on July 4th, 2003 at 06:48 PM
CB Performance sells a dry sump system that is a direct bolt on for the standard oil pump. They also claim 9 hp on the dyno.
regards
Jak
I've attached the link for it
http://www.cbperformance.com/catalog.asp?ProductID=189
Congratulations to Ben Durie for breaking the hillclimb record at Ringwood in his stroker beetle!
