| [ Total Views: 5748 | Total Replies: 11 | Thread Id: 80513 ] |
crzbug67
Threads: 6
| posted on November 28th, 2009 at 01:18 AM |
Subaru ECU pinouts needed
hi i am in the process of converting to EJ22 power but the engine and computer i have got are out of a 6/94 model liberty so it has a three yellow
plugs at the ECU and i can not for the life of me find anything that matches any help would be greatly appreciated the model number of the ECU is UI
22611 AB640 A18-000 RV2. Thanks
seagull
Threads: 752
| posted on November 28th, 2009 at 02:24 AM |
This is a gen 2 liberty . Super cheap , repco have the manual for this
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on November 28th, 2009 at 12:24 PM |
I,ve edited this post to remove the diagrams which are incorrect.
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on November 28th, 2009 at 12:28 PM |
I also have a diagram for a SOHC EJ20 which is also for the 3 plug ECU, it also seems to be right. But I have not got around to comparing it to the
above diagrams yet.
Quote of the week
crzbug67
Threads: 6
| posted on November 28th, 2009 at 06:06 PM |
Thanks for your replies i will check this out tomorrow i have a manual which is almost right with the color codes but there is no pin outs of the ecu
jzk25
Threads: 3
| posted on December 6th, 2009 at 06:57 AM |
That pinout is not correct for an EJ22 Aus engine. There is also 2 different pinouts and ecu's that will run the same engine in the Gen 2 Liberty so
be careful which you use. 94-96 is different to 96-98.
You could always pay $250 and get the wiring stripped, prepped and labelled for you. Connect B+, Ign switch and Starter signal and it'll run.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on December 6th, 2009 at 02:51 PM |
Yes I get it you make looms, doesn't help us out finding a pinout thought.
Quote of the week
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on December 15th, 2009 at 01:42 PM |
crzbug67 try your local libary, I just found some diagrams there. "EFI and Engine Management" (the are 4 volumns) or the Liberty manual.
Quote of the week
jzk25
Threads: 3
| posted on December 23rd, 2009 at 06:00 AM |
Merry Christmas. Blame photobucket for them being upside down.
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on December 23rd, 2009 at 05:52 PM |
Thanks for that, just had some time to compare it with what I got at the library the other day. Corrects one terminal of I have and fills in all the
details that don't get included in the non factory manuals.
Cheers and Merry Christmas
Quote of the week
crzbug67
Threads: 6
posted on December 24th, 2009 at 01:37 AM |
Yea thanks allot this is the best Christmas present i have got this year
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
| posted on January 1st, 2010 at 03:52 PM |
Put this in a more readable format, let me know if you find any errors and I will fix them up.
| Error |
Quote of the week
