[ Total Views: 540 | Total Replies: 1 | Thread Id: 8252 ]
Author: Subject: Dipstick sender
Memberwaltermitty
Mood: Hungry for mor
posted on July 8th, 2003 at 05:04 PM
Dipstick sender
I have a dipstick sender (-BERG) and thought that I might give it a go. Its fairly obvious to me where i install it but where do you connect the wire too?
Thanks . MitCheLl:cool:
23 windows ...8 too many!
posted on July 8th, 2003 at 05:19 PM
On the temp gauge there should be 2 terminals.
One goes to the sender unit and the other side goes to a positive on the fuse box that activates when the ignition is turned on.
The temp sender sends a resistance signal to the gauge that makes it moove when the oil temp increases.
MemberKeith Haeusler
Threads: 40
posted on July 8th, 2003 at 06:14 PM
Mitchell,
The wire hooks to the oil pressure light wire. Use a piggy back from the o/p switch to attach both wires. Keith.
Membervwtestpilot
Threads: 1
posted on July 8th, 2003 at 09:17 PM
Check it out here...
http://www.geneberg.com/tempdipstickhtm.htm
Barry.
