| [ Total Views: 1540 | Total Replies: 10 | Thread Id: 82760 ] |
jjwebb123
A.k.a.: Jason
Threads: 63
Mood: Trying to get it puring
posted on March 25th, 2010 at 06:03 PM |
2.0 litre engine and gerbox bolt straight in?
We found a kombi 75 for sale,the body is full of rust but straight and it has a 2litre in it.My question is can we rip the gearbox and 2liter engine
out and bolt it straight into our 72 Lowlight removing the current 1600 engine? Can that be done and is it hard?
Have a good one.
"A car for the people, an affordable Volkswagen, would bring great joy to the masses and the problems of building such a car must be faced with
courage."
tar76
Threads: 95
| posted on March 25th, 2010 at 06:17 PM |
Should be able to into a 72. what i am to beleiveis the 72 has the bigger engine bay
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
jjwebb123
A.k.a.: Jason
Threads: 63
| posted on March 25th, 2010 at 06:46 PM |
yeh it is quite wide.Any other info needed
courage."
Joel
| posted on March 25th, 2010 at 07:39 PM |
yea 72 was the first year of the type4 engine bay so should be a straight swap
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on March 25th, 2010 at 09:24 PM |
You will need to shorten the gearshift linkage at the front by about 10mm so you can select all the gears. The 2L box is longer than the 1600
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
matberry
| posted on March 25th, 2010 at 10:04 PM |
posted by 11CAB
Or just swap the shift rod.
jjwebb123
A.k.a.: Jason
Threads: 63
| posted on March 26th, 2010 at 09:31 AM |
Are the 2L gearbox's any better,like better gearing and stuff?
courage."
matberry
| posted on March 26th, 2010 at 01:44 PM |
2.0 l engine needs the gearing of the 2.0 l gearbox, assuming tyres are still the same as stock diameter. Also need the bell housing to fit in the
clutch that is bigger than all the rest.
Woz72
Threads: 1
Mood: lager
| posted on March 26th, 2010 at 07:16 PM |
The "2 litre" 091 has similar gearing to the "1600" 002, really only differing only in the final drive ratio.
...Woz
'72 kombi camper
jjwebb123
A.k.a.: Jason
Threads: 63
| posted on March 26th, 2010 at 08:53 PM |
,ok,should we should be good to just swap the running gear over then.wont have to change mounts or nothing like that?
courage."
greedy53
Threads: 468
Mood: strung out
| posted on April 4th, 2010 at 08:35 PM |
i have just finished that fit up i have a 72 ute and a 76 2 lit and gear box it's a straight swap cut nothing or move anything ,the 72 is a special
beast it has a wider undercarrage and is 4 inches longer ,it can fit any engine that vw make from the 1600 1800 and 2 lit,and just to add a bit of
go0ld the 2.1 water pumper will go straight in also
so have fun
