| [ Total Views: 1488 | Total Replies: 15 | Thread Id: 83593 ] |
pete wood
| posted on May 11th, 2010 at 09:02 PM |
Big, dumb, stupid NA ej motors? (attn seagull)
Is anyone building em?
What would it take to get an EJ25 NA to pull 8000rpm and 300hp on premium pump fuel?
What stroker cranks/big bore pistions are available for them?
JVLRacing
Threads: 30
| posted on May 11th, 2010 at 09:14 PM |
A good question for seagull for sure.....
I would start with head work and manifold...
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on May 11th, 2010 at 09:22 PM |
posted by pete wood
haha...they produce bugger all in standard form, good luck in getting those numbers !
pete wood
| posted on May 11th, 2010 at 09:48 PM |
Torrens: Well you should know about motors that produce "bugger all". You've got a shed full of em!
JVL: i've heard the heads flow great numbers standard, so surely cams would be the first things... which unfortunately means instant aftermarket ECU.
Then yes, some ITBs... mmmm, ITBs...
Joel
| posted on May 11th, 2010 at 09:53 PM |
Pete, they punch 200hp stock with only aftermarket management
300 might be aiming a bit high staying N/A but i reckon you could get close by bumping up the CR, bigger injectors, some decent headwork, better cams,
port the intake and exhaust and get a well designed header system made up etc
alot of work though, do you really need that much power in a buggy?
pete wood
| posted on May 11th, 2010 at 10:26 PM |
"need" is an interesting word. "want" is probably closer.
Craig Torrens
Threads: 347
| posted on May 11th, 2010 at 11:34 PM |
posted by pete wood
........yeah but a garage full of performance vehicles
Joel, are you talking atw or flywheel ?
matberry
| posted on May 11th, 2010 at 11:48 PM |
Think he's talking about those little japanese horsepowers. lol
mactaylor
Mood: even my dog is german
| posted on May 12th, 2010 at 06:40 AM |
good idea pete a stripped down ej 25 with ITB's would make for an interesting project heads have got plenty of meat for porting and aftermarket OS
valves are cheapish, cams no probs, would sound great to!
EVERLAST CONCRETE TANKS
1800 552 123
rocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
| posted on May 12th, 2010 at 07:12 AM |
SC14? why be pedantic about NA?
pete wood
| posted on May 12th, 2010 at 11:28 AM |
Simple rob. I can't go turbo/blown on my motor legally. Besides, NA motors are a different animal but they are still good fun.
I'm sure Craig and Matt would agree with me on that.
Joel
| posted on May 13th, 2010 at 05:48 PM |
posted by Craig Torrens
one would think flywheel with those kinda figures but i cant see many of these subaru guys having their engines removed to be bench dyno'd so who
knows
seagull
Threads: 752
| posted on May 14th, 2010 at 12:22 AM |
Paul here in perth is building a 2.5 n/a motor ( 257 sti block ) sti con rods with 2009 legacy heads, plastic inlet manifold , mechanical throttle
body, headers
I gave him a set of STI bug eye cams tonight, they fit the heads but need to check the lift ect
The ecu is a mega squirt, he is looking for 200+ hp
Klaus
Threads: 100
Mood: Heavily modified
| posted on May 15th, 2010 at 11:39 AM |
i have a na ej25 dohc that needs rebuilding $150.00
seagull
Threads: 752
| posted on May 15th, 2010 at 03:16 PM |
year ?
Klaus
Threads: 100
| posted on May 16th, 2010 at 07:03 PM |
97 with reco heads but stupid previous owner ran it with rad pipe leaking so blew headgaskets again
