[ Total Views: 1897 | Total Replies: 10 | Thread Id: 84504 ]
Author: Subject:  Which Gearbox EJ22
MemberMR930
Threads: 73
Mood: VW crazy.
posted on June 26th, 2010 at 08:40 PM
Which Gearbox EJ22
Just wondering which gearbox has the best ratios for an EJ22 running 17in wheels. Its going in a Kombi but I have no problem fitting a single sideplate Beetle box if that has the best ratios.
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 26th, 2010 at 10:00 PM
u having rubber bands on the 17 inch wheels? or going tall tyres?
(ô_!_/ô) (ô_!_/ô)
Memberseagull
Threads: 752
posted on June 26th, 2010 at 10:57 PM
I think the one Humpty did had the single side gear box.
Memberseagull
Threads: 752
posted on June 26th, 2010 at 11:02 PM
super bug ratio
MemberOZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
posted on June 27th, 2010 at 10:17 AM
091 Mark
Memberblackbuka
Threads: 2
posted on August 17th, 2010 at 01:22 AM
hey seagull do you have adapter plates and flywheels available??
MemberBlueV2
A.k.a.: Mark
Threads: 15
posted on August 17th, 2010 at 02:06 PM
I have an adaptor plate and flywheel for a 091 box conversion....and a modified Subaru starter that bolts straight up to it !!!
Sharpbuilt V2, EJ25, Subaru 5 Speed, Falcon rear discs, Heater & A/C, Rack Steering
MemberDylanTheDubber
Threads: 173
posted on August 17th, 2010 at 05:51 PM
Yes Single side plate superbug box is the best. it has the talest top gear ratio they goe quite well with a EJ22.
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on August 17th, 2010 at 06:56 PM
If it is going in a bus, then a 2 litre bus box will be a great way to handle the power. Albins gears will make almost any ratio you want. It bolts straight into the bus too.
Memberttriebler
Threads: 16
posted on August 17th, 2010 at 07:37 PM
Or you could actually use the Subaru 5 speed gearbox that was designed and made for the EJ22. No need for fancy Albins gears, custom flywheels and adapter plates. Here's a short video that gives you some idea of how well it goes on the freeway.
http://www.youtube.com/watch?v=TvcGwHuaCdY
Reversed gears for Subaru transmissions.
Fit a Subaru 5 speed to your rear engined car
www.subarugears.com
posted on August 17th, 2010 at 09:04 PM
mr triebler has a good point. cost less too.
