[ Total Views: 1961 | Total Replies: 7 | Thread Id: 84506 ]
Author: Subject:  Help needed
Memberajp3830
Threads: 1
posted on June 26th, 2010 at 09:19 PM
Help needed
I noticed a noise developing in the rear end of my T3 as I was driving my son to a soccer game. This sound was initially a low grone which seemed to ease as I accelerated.
During the return journey Beerwah to Bli Bli (near Maroochydore) the noise gradually grew worse.
Arriving home I checked engine oil (2.1L engine/auto), automatic transmission fluid.All OK.
Im thinking that a cv joint may be on the way out.
Q DO you think Im on the right track ie cv joints. Is there an easy way to check these, and are they easy to change ie DIY
Im searching for ideas
I also was thinking the Automatic Differential oil could be a problem, but it has not been leaking so Im fairly sure its OK
Finally (yes theres more) would anyone know of any good workshops ,mechanics ie T3 familar on the Sunshine Coast Qld 100k north of Brisbane
posted on June 26th, 2010 at 09:28 PM
CV's usually make a clicking noise when goinground corners
Oh - welcome
Love T3's
I have an 89
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 26th, 2010 at 09:59 PM
As bizarre said, dead or dying cv's click on corners, Bearings make a consistant deep noise like a set of a noisy tyres but a little louder and is noisy consistantly.
Usually low oil in a gearbox whines, but no harm checking diff oil. can't tell ya what that sounds like, i have only ever had combined diff and transmission 'transaxles'.
(ô_!_/ô) (ô_!_/ô)
Memberajp3830
Threads: 1
posted on June 26th, 2010 at 10:17 PM
Maybe not CVs as I dont have the clicking sound. Will check diff oil 2morrow. I d love it to only be a bearing but will see
Memberajp3830
Threads: 1
posted on June 27th, 2010 at 07:46 AM
Thanks for advice as it all helps. Now to pin point the prob.
I will let you know the outcome
Memberajp3830
Threads: 1
posted on June 29th, 2010 at 06:19 PM
Update.
Found one collasped wheel bearing so bad it allowed play in wheel at rear.
Memberpod
A.k.a.: paul mrvw061
Mood: could be better
posted on June 29th, 2010 at 06:30 PM
try matberry on here for a mechanic up your way
check wbsite for location
All Welcome
http://www.flatfour.org/
Memberajp3830
Threads: 1
posted on July 1st, 2010 at 11:10 PM
Originally posted by pod
try matberry on here for a mechanic up your way [/quote
Thanks for that tip .
I discovered Mick Budge ,who ended up doing the repair.
[ Queries: 40 ] [ PHP: 19.2% - SQL: 80.8% ]
