| [ Total Views: 1213 | Total Replies: 7 | Thread Id: 84862 ] |
karmanngirloz
Threads: 8
| posted on July 18th, 2010 at 02:02 PM |
EMPI 5 Spoke Wheels - Tyre Advice
I have a set of empi 5 spokes and was wondering whats the best tyres to get. I have seen ghias with a set of Yokohamas but the tyre looks pretty close
to the body. Is there any rules in the esafety check about cleareance between the tyre and body?
empi
A.k.a.: Empstar
Mood: thunderous
| posted on July 18th, 2010 at 02:09 PM |
165s on the rear, they will bolt on if yr car is pre 64 (Thinner drums) later u will need an axle swap, or jack up the car to get clearance.
"If at first you don't succeed, skydiving is not for you." - Anonymous
newghia
A.k.a.: Noddy
Threads: 30
Theme: UltimaBB Pro Charcoal
Mood: nood !
| posted on July 18th, 2010 at 02:17 PM |
i have 195 / 50 / 15 yoko's on mine & yes it is close to the gaurds, look for something a little narrower
Nath
Step up to get out !!!
Tazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
| posted on July 19th, 2010 at 09:06 PM |
175/65/15 nankang's.... i'll post some pics of the square when the new ones are fitted sautrday.
these are 205/60/15's one rear and 205/50/15 front
these are 165/80/15's on the square now but changing
Tazz
1962 Type3 Squareback
1967 Type3 Fastback "Kermit"
empi
A.k.a.: Empstar
Mood: thunderous
| posted on July 19th, 2010 at 09:40 PM |
The square has the thinner drums hence being capable to lower, the fasty would rub on the tyres if u were to lower.
Here is my 63 with 5s
| Error |
Beerboy
Threads: 147
| posted on July 20th, 2010 at 11:24 AM |
Its for a karman ghia ;-) 165x15 which are the standard tyre I expect you have on it will fit the 5 spoke. more modern tyres are better as they will
be wider and give you more grip. On the note of clearance I don't think any blue slip place will worry as long as you look safe.
welcome to the forum by the way
WANTED kombi drivers side rear corner for a early bay! found after six years lol
WANTED engine lid for early kombi 71
empi
A.k.a.: Empstar
Mood: thunderous
| posted on July 20th, 2010 at 06:51 PM |
Tyre tread is the main thing they look at , depends on yr gearbox axle tube length (Short up to 67 longer 68 +) i haave fitted 185/55/15s on a lowered
Karmann with 5s without too much issue..... keeping in mind all KGs are hand built and body work can differ.
Tazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
| posted on July 26th, 2010 at 10:01 PM |
posted by empi
Square has all 67 fastie brakes on it..... the 62 drums are crap.... lol
Tazz
