[ Total Views: 1394 | Total Replies: 2 | Thread Id: 8600 ] |
Adam_C
Threads: 164
Mood: could be lower
posted on July 19th, 2003 at 06:13 PM |
Spray guns
When painting the notch i was told i needed a putty gun or some other typr of gun to spray highbuild primer
is this true or could it be sprayed with my normal gun?
(Star gravity feed)
adz
Adam
Adzslick@iprimus.com.au
duncombemu
A.k.a.: Mark Atkins
Threads: 39
Mood: Be cool.
posted on July 19th, 2003 at 11:16 PM |
A spray putty gun and a paint gun are two different guns. A putty gun runs at a lower pressure than the spray gun.
Regards,
Mark:thumb
Don't ever let anyone tell you, "It can't be done."
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on July 20th, 2003 at 10:14 PM |
It would be advisable to ask the place you buy the products from, as some products are able to run through a normal gravity feed gun also.
It is usually commonpractice to keep putty and colour spray guns seperate so as to not contaminate the colour gun with bits of putty.
Althogh if you are cleaning your equipment properley this should not matter.
I puttied up and primed and sprayed adout 50 cars in acrylic laquer using the one same gun (Star 77)for about 6 years.
DubCrazy
A.k.a.: steff
posted on July 22nd, 2003 at 12:13 AM |
to spray highfill 2K you will need a 2.0 to a 3.5 fluid tip on your gun... suction or gravity fed... ... depends on what product you are useing e.g
PPG 2K ms will need a 2.0 fluid tip. but to use the PPG deltron high fill u will need a 3.0 ... your paint supplier should be able to tell you what
set up will work the best |
jonno-t3
A.k.a.: johnathon cooper
Mood: stewed
posted on November 7th, 2003 at 10:07 PM |
i got told that high fill primer and filler/primer are different things. the filler primer has filling propertys but is thinner than the high fill and
it can be sprayed through a normal gun. which is what i have done.
high fill however, is supposed to be really thick and comes off ripply if your not too carefull..its like spraying liquid bog. u need a special gun to
spray it.
i dunno if this is true or not, but thats what i was told.
hope that helps.
jonno
"if only everything in life was made like a volkswagen"
