| [ Total Views: 2110 | Total Replies: 27 | Thread Id: 86102 ] |
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
| posted on September 20th, 2010 at 08:52 AM |
Warwick prep. Dyno results
I have been way too busy to finish my new drag car and have had to go to plan B , and modify my circut car for the drags . I have removed the engine
and transmission from the car and replaced it with a purpose built deal .
The engine I have just assembled from all of the parts laying around here has just returned from a dyno session where it produced 191 HP and 288
ft/lb's of torque . These figures were at the wheels and were made with a full cooling and charging system operating with a full sized pulley . The
engine is built on a new Magnesuim case , 82mm Demello full circle wedgemated crank , 5.4" h beam rods , AA 94mm Racing pistons , Pauter cam similar
to an FK 89 , a set of Welded and ported Comp Eliminator heads with 46 x 38 stainless valves and 12.8 comp . I was using the Sunoco supreme nos as the
fuel and changed to BP 98 and picked up more power . The exhaust is a 1 7/8 header with a stinger and with the muffler the engine made 188 HP .
The transmission is built on a Rhino case , a full set of Albins gears and a locked diff . I am using the same 930 cv set up that was on the car . I
am doing some maintance on the car and it will be in the trailer and ready by Wednesday , I will see you on the north side of the border , ROD.
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on September 20th, 2010 at 10:47 AM |
cnfabo
Threads: 140
| posted on September 20th, 2010 at 06:12 PM |
jeez, nice hp numbers rod....
modulus
A.k.a.: Peter Hill
Mood: modular
| posted on September 20th, 2010 at 06:24 PM |
Blimey, 12.8:1 with 98 octane pump fuel... Don't you need avgas for that sort of C/R?
Yours uninformedly,
matberry
| posted on September 20th, 2010 at 06:46 PM |
Great result Rod
Keith Haeusler
Threads: 40
| posted on September 20th, 2010 at 06:56 PM |
Rod,
Thanks again for the offer. Had a great day and was good to put names to faces.
Bring on Warick!
Regards, Keith
Gracey
Threads: 17
Mood: Itchy
| posted on September 20th, 2010 at 07:42 PM |
Nice result, what intake are you using?
cnfabo
Threads: 140
| posted on September 20th, 2010 at 09:56 PM |
i think 51 ida's
RodPenrose
Threads: 330
| posted on September 21st, 2010 at 08:23 AM |
Gracey , I am using a new set of the Empi 51mm carbs . I tried several different size venturies and ended up with a set of 45mm that seem to be a
compromise between drivability and high revs . The intake maiifold is an original Superflow component , welded and matched to the head , ROD.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on September 21st, 2010 at 08:47 AM |
Any other results of other cars there ? Rod .What octane , or figures on the sunoco fuel .
Good to see ,that you will be racing at Warwick.
SuperOwen
Threads: 67
| posted on September 21st, 2010 at 11:48 AM |
Not sure if the owners want details posted but all the other cars made good results, minor jetting and timing changes picking up good power in some
instances. No breakages either!
Keith Haeusler
Threads: 40
| posted on September 21st, 2010 at 05:14 PM |
Hi,
Can`t speak for the others but i managed 177hp from my engine. Still a little rich so hopefully can squeeze some more out of it.
Cheers, Keith
FROSTY
Threads: 65
| posted on September 21st, 2010 at 05:49 PM |
Nice work Rod, I saw your car at the Raleigh track day...what a weapon, can't wait for you to cane the guts out of it at Warwick.
FROSTY
Threads: 65
| posted on September 21st, 2010 at 05:51 PM |
By the way has anyone got a photo of Rod's car??
Paulc1964au
| posted on September 21st, 2010 at 06:13 PM |
Here is Rods car at Wakefield i think this is the car he is using at Warwick
FROSTY
Threads: 65
| posted on September 21st, 2010 at 06:54 PM |
thanks Paul !!
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on September 21st, 2010 at 07:51 PM |
Well done Rod, looking forward to catching up at Warwick and seeing how these dyno numbers translate into on the eighth mile.
Also good to hear your engine is running sweet Keith!
Al
Gracey
Threads: 17
Mood: Itchy
| posted on September 21st, 2010 at 08:02 PM |
posted by RodPenrose
Thanks Rod,
Another question.......at what revs is it making max hp?
colin
Threads: 82
| posted on September 21st, 2010 at 08:41 PM |
posted by Keith Haeusler
Hi,
Cheers, Keith
Nice one Larry!.
Do you think we could get 177hp out of my old tired 1916?, LOL.
Cheers Col
Klaus
Threads: 100
Mood: Heavily modified
| posted on September 22nd, 2010 at 04:34 PM |
Went along to see if the old type4 made some more power.
engine is a tired 2ltr ex injected bottom end so has hydraulic lifters .
smallest heads as in port / valve for type4 just mild port job to blend exh ports
40mm italian webers with update kit
dis ix ignition
custom 1 5/8 tuned length extracters and modified muffler
last time out it made 55hp with 122 ftlbs but heads had blown hedgaskets burnt exh valves and cracked heads
this time with newer heads that seal
65.7 hp and 136ftlbs so happy that the shagged motor can still make good power for what it is
motor is in a 62 split panel with upright kit
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on September 22nd, 2010 at 05:55 PM |
managed to get 147 rwhp out of the drag rat bug, a little more than morgan, before he hit the cheeter button !!!!Now the cars are finished just have to get stuck into the trailers and tow vehicles, so we can get
them up there.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
| posted on September 22nd, 2010 at 08:32 PM |
Ha , Ben how much nitrous did Morgan shoot ? Thanks for sharing .
Anyone have pic's
whathaveidone
Threads: 98
| posted on September 22nd, 2010 at 08:50 PM |
ill let him tell that! Dont think anyone got any photos but i did get a video of a monster truck driving up the street!!!!!
humpty
Threads: 139
Mood: Totally boosted!
| posted on September 22nd, 2010 at 11:10 PM |
Shit.... This really sucks... Gonna miss another Warwick.... But maybe I'll catch some of you guys at Portland?
RodPenrose
Threads: 330
| posted on September 23rd, 2010 at 08:09 AM |
Gracey , We were tuning from 70 to 160 km/h , and the engine was on 191 when we finished the run . This was at 7080 rpm's and I think there is more
power available . The max torque of 288 was at 5750 rpm and didn't drop off much at 7080 . The engine will be good for 8500 rpm and I don't know
where the max. power will be . I am changing wheels now to allow me to use a treaded slick to hold the power , ROD.
oldskl60
Threads: 28
| posted on September 23rd, 2010 at 10:40 AM |
great news guys.
looking forward to warwick - sounds like there will be a good number of tough n/a "street" cars...
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on September 23rd, 2010 at 06:21 PM |
Shouldn't you have done full power runs to find out where the max power is Rod?? Seems kinda fruitless to only dyno to 7k when the thing will
possibly run to 8500?? Peak power might only be at 8000 but I guess you won't find that out unless you do full power runs to the limiter. Hopefully
you have enough fuel in the thing so it doesn't run real lean in that last 1500rpm or so or I might have to bring a mop and bucket for the clean up
LOL
Gracey
Threads: 17
Mood: Itchy
| posted on September 23rd, 2010 at 07:14 PM |
Thanks Rod
