[ Total Views: 1015 | Total Replies: 3 | Thread Id: 86691 ]
Author: Subject:  62 ghia headlights
Membergrogy
Threads: 344
posted on October 20th, 2010 at 09:55 PM
62 ghia headlights
hi, who can tell me what i need to do to change my headlights to 12volt, besides battery/ geny/alt, just the headlights. thanks greg
yes.gif posted on October 21st, 2010 at 12:28 AM
7 inch headlamps..
You only need to change the bulbs/globes if its an Aust spec Karmann Ghia..
You would need to take the 6 volt bulb out the rear of the headlamp and take it to a VW Shop...
some of the 6 volt bulbs are very hard to find in 12 volt these days...
The USA specs had sealed beams....
just ordinary 7 inch..12 volt Hi/Lo sealed beams
it may be easier to buy new semi sealed beams from a VW parts shop... [much cheaper then Auto one etc...]
and also bright H4 sealed or semi sealed beams..
Membermatara
Threads: 255
Mood: 356'd
posted on October 21st, 2010 at 09:22 AM
Cheapest Option
If your not too fussed about originallity, or you want to save those expensive to replace stock headlights, you can fit mini headlights with 7" sealed beams. You can buy them brand new from mini suppliers very cheap and they fit remarkably well.
Standard Headlights
http://www.matara.net/albums/ghia/9_G.jpg
Mini Sealed beam headlights:-
http://www.matara.net/albums/ghia/IMG_2355.jpg
Membergrogy
Threads: 344
posted on October 21st, 2010 at 10:12 PM
thanks lee n steve, greg
[ Queries: 40 ] [ PHP: 11.1% - SQL: 88.9% ]
