| [ Total Views: 628 | Total Replies: 12 | Thread Id: 87692 ] |
Bizarre
| posted on December 18th, 2010 at 12:46 PM |
WTD - L Bug wiper arms
I am after a set of L bug wiper arms
I am ONLY after the original Left and Right versions with blade holder ( I can buy the actual blade)
I am NOT after the the new aftermarket style that has flat blades. They do not work.
I have the longer left arm - but not the left blade holder.
Right Arm - short
Right Blade - long
Left Arn - long
Left blade - short
2 right arms I can work with as well
barry
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on December 18th, 2010 at 01:24 PM |
can do, pm me your adress, $20 + post or wait till Thursday I'll be in Sydney on the way to int. airport.
Bizarre
| posted on December 18th, 2010 at 02:14 PM |
Done and you have PM
1303Steve
| posted on December 18th, 2010 at 08:42 PM |
Hi Barry
After you after the Aussie made Tryco ones or the German style? The Aussie ones have a pin on the end, the German ones have a hook. I bought German
ones from VW Heritage in the UK. I might have some Aussies ones floating around.
donn
Threads: 428
| posted on December 19th, 2010 at 05:44 AM |
No Pm, I'll check to see what type I have regarding Steves post.
Bizarre
| posted on December 19th, 2010 at 07:27 AM |
pretty sure I dont care - the ones I have are the Australian version. If German are better than great
As lons as they are complete with arm and blade and take the universal slide in rubber blade you get from Autobarn
What I dont want are like the Bosh replacement ones
Donn
I will try again
Bizarre
| posted on December 19th, 2010 at 07:32 AM |
These are the rubbish Bosh blades that I dont want
Bizarre
| posted on December 19th, 2010 at 07:45 AM |
This is what I am after
donn
Threads: 428
| posted on December 19th, 2010 at 08:21 AM |
Got your PM. Looks like I have the ones you are after though they are black (bit chipped) a close up of the wrong type would be helpfull, not sure how
the end comes off the arm, have tried but don't want to force the issue, they have those small tabs on the ends of the arms which look like they are
meant to be spring loaded to remove the blade holder. I'll have to check our path to the airport as we will be in a bit of a hurry, you may have to
meet me somewhere. Do you want all the rubbers?
Bizarre
| posted on December 19th, 2010 at 09:31 AM |
Dont really have a close up as I threw them away
The ones I want have a single piece that the rubber blade slides in to
The Bosch ones are like 2 holders on the blade
See if this works -
https://www.classicveedub.com.au/cvd_new/part_detail.aspx?parts_id=16081
As for the rubbers - I am after the 2 door only
If you go Victoria Road way you pass VERY close to my place - then into the city - tunnel and you are there
Joel
| posted on December 19th, 2010 at 01:55 PM |
The Original trico aust ones are all metal, those crappy replacements are plastic.
If you get really stuck I have got a pair of original trico ones but there abit worn in all the joints
donn
Threads: 428
| posted on December 19th, 2010 at 03:51 PM |
Ok these have the Trico stamp, looks like we are on a winner.
1303Steve
| posted on December 19th, 2010 at 09:02 PM |
I bought a set of wiper blade holders with an airfoil on them from Super cheap, I fitted them to my sons bug and they seem to be holding up really
well.
When I started building my new 1303 I had a mishmash of wiper arms so I bought some from VW heritage, they still have them but they are 22.43 pounds
each, yikes.
| Error |
