[ Total Views: 609 | Total Replies: 6 | Thread Id: 88396 ] |
zedman
Threads: 17
Mood: Varies with my finances
posted on January 28th, 2011 at 06:23 PM |
Oil leaks.
My little flowers 89 caravelle has a oil leak which is dotting the back window with oil spots, am thinking engine seal.What should i look for if i
drop motor out.Any tips appreciated.
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on January 28th, 2011 at 06:32 PM |
New rings
rear main seal
Keeping it real !
clinker42
Threads: 154
posted on January 28th, 2011 at 08:00 PM |
What about a good degrease and clean and then see if you can spot the leak.
If you pull the notor then I would do a quick reco, hone the bores, polish the crank, new bearings and rings
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 28th, 2011 at 08:24 PM |
put Nulon (or any other brand) "stop Leak" in the oil................works a treat
greedy53
Threads: 468
Mood: strung out
posted on January 28th, 2011 at 08:31 PM |
is it auto when i had one the auto was leaking and it covered the back window with oil took a bit of head scratchng before it was solved
matberry
posted on January 28th, 2011 at 10:10 PM |
Oil leaks on a T3....I'd be checking one of the oil pressure senders for the source. Degrease and have a very close look to see exactly where its
coming from.
zedman
Threads: 17
posted on January 29th, 2011 at 11:12 AM |
Thanks for the help fella's.degreasing today then sorting problem from there.One more query though, how difficult and costly to replace rear brakes
with discs? Cheers.
