| [ Total Views: 682 | Total Replies: 5 | Thread Id: 88462 ] |
jjwebb123
A.k.a.: Jason
Threads: 63
Mood: Trying to get it puring
posted on February 1st, 2011 at 05:51 PM |
My 1970 beetle Acting a bit sick.
Hi Guys,a little problem with my clemy.
The other day,coming home for lunch from work,my 1970 (clemy) beetle just didn't sound right.It ran fine at high revs but when slowing down to
intersections would just start to spit and quietly stall.It happens 3 times each at an intersection.The rest i went through i had to knock it into
neutral and than handbrake while keeping the revs up.
To me it sounds like a spark problem,but then at the same time sounds like fuel problem.I have an electronic dizzy,new leads,new carby.i went chasing
new plugs today but to no avail,will try again tomorrow.Can anyone think of anything else it could be? just chasing some different opinions.it cant be
much.it got me there in the morning.
Thanks Guys.
"A car for the people, an affordable Volkswagen, would bring great joy to the masses and the problems of building such a car must be faced with
courage."
vwo60
Threads: 71
Mood: good
| posted on February 1st, 2011 at 06:16 PM |
Try the idle solinoid valve on the side of the carb, the wire could have come of or the coil has gone open circuit
Joel
| posted on February 1st, 2011 at 07:39 PM |
piece of crap caught in the idle jet
jjwebb123
A.k.a.: Jason
Threads: 63
| posted on February 3rd, 2011 at 04:34 PM |
ah ok,yeh i didnt think of the solinoid.what do you mean coil gone open circuit?
courage."
jjwebb123
A.k.a.: Jason
Threads: 63
| posted on February 5th, 2011 at 07:32 PM |
tested the idle solenoid and its all good.getting power there.must be the jets.is there a way to like blow the jets out?
not real sure on pulling it apart.my fuel is running low and there is no inline fuel filter so i am thinking it maybe picked up a bit of s*@t.
courage."
68AutoBug
posted on February 5th, 2011 at 08:14 PM |
posted by jjwebb123
Thanks Guys.
Get spark plugs from VW parts shops....
BERU BOSCH or NGK..
sounds like the idle jet is blocking up....
this is common with new carburetors.... [so I've read]
they aren't cleaned out properly after drilling...??
