[ Total Views: 1041 | Total Replies: 9 | Thread Id: 88501 ] |
clinker42
Threads: 154
posted on February 3rd, 2011 at 03:56 PM |
POOR MANS TWIN CARBS
Hi Guys
Whats a single barrel carb that one could get two of and stick on 1600 beetle engines
Maybe the old strombergs that came out on the Holdens
Making manifolds isnt an issue, nothing some alloy and a tig cant fix.
Any ideas
sander288
"Bolt-on Master"
Threads: 183
posted on February 3rd, 2011 at 04:09 PM |
old type 3 carbs; they would be perfect;
alot of VW shops have them lying around but I think any solex carb can be used as twin carbs providing you get the linkage to work
if your after old carbs talk to Boris at Vintage Vee Dub
Another carb to think of is the SU which were used abit in the 60's; from all reports they ran very well on 1200 bugs and have endless adjustment
SHaun
pod
A.k.a.: paul mrvw061
Mood: could be better
posted on February 3rd, 2011 at 04:21 PM |
i used twin pict 28 solexes on my 1300 with home made manifolds,gave more grunt and a little more top end
Bizarre
Threads: 732
posted on February 3rd, 2011 at 04:59 PM |
Kombi Kim had a set of dual progressives
grumble
Mood: happy all the time
posted on February 3rd, 2011 at 07:47 PM |
I still have a pair of twins off a 1500 wagon motor,a lot of years ago we used a pair of strombergs off the EH holden,with venturi reducers &
adjustable main jets very successfully.The Ghia went very hard with these fitted,there wasn't much around that came close to it's performance in
those days.Fortunately my hoon days are over & I am happy to just cruise .
matberry
posted on February 3rd, 2011 at 08:00 PM |
Twin Type three with later type 2 34mm throttle plates. CLA special
vlad01
Mood: Side ways
posted on February 3rd, 2011 at 08:23 PM |
quad stromberg
71 notchback,
Joel
posted on February 3rd, 2011 at 09:12 PM |
Quote: | Originally
posted by Bizarre
Just one of them is bad enough, let alone 2 of the bloody things.
Main problem with using any random carbs as twins is clearance mainly to the fanshroud but also to the body.
Cheap kadrons come up on ebay all the time, I sold my set for $250
Or as mentioned type3 PDSITs if you can find a non worn out pair.
i ran them on my bug for a bit, theyre ok if you get the linkage working well.
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 295
posted on February 3rd, 2011 at 09:17 PM |
Quote: | Originally
posted by Bizarre
| twoguns use to run these on his splity
1916baja
Threads: 176
posted on February 4th, 2011 at 04:53 PM |
when you say "poor mans", how much do you wanna spend? rod sells kadrons for about $500 a kit.... I had one of his second hand kits on my baja and
they were great.
