| [ Total Views: 890 | Total Replies: 5 | Thread Id: 88642 ] |
DannyW
Threads: 12
| posted on February 9th, 2011 at 02:52 PM |
WTB centre mount fan shroud
After a centre mount fan shroud with stand, the right hand offset standard one fouls on my new intake.
can't seem to find anything as yet in Australia so hopefully I have some luck on here
1916baja
Threads: 176
| posted on February 9th, 2011 at 04:12 PM |
Call rod penrose.
Joel
| posted on February 10th, 2011 at 09:26 AM |
What have you got for an intake thats fouling a standard one?
36hp shrouds free up heaps of room and atleast flow reasonably
Testing done showed those centermount shrouds are one of the worst performing ones availble.
You only have to look at the design of them though to work that out.
DannyW
Threads: 12
| posted on February 10th, 2011 at 04:17 PM |
the motor has the comp eliminator heads from CB as well as a 45DCOE side draught which sits just above the transmission. There is no way a stock
shroud will fit in the area I have even after I re bent all the intake tubes to make more room. My only other option is to cut up the one I have and
place the generator in the middle and re bend all the internal air ducts which will be a pain, I'd rather get a centre mount shroud and cut it open
and add the air ducts myself if I have to.
dogo
A.k.a.: Noddy Goodboy
Mood: on another Planet..
| posted on February 10th, 2011 at 05:37 PM |
Be easier to make a new manifold?
DannyW
Threads: 12
| posted on February 13th, 2011 at 10:24 AM |
no way, it has taken many weekends to get it right, looks like I will be making a shroud from scratch
