| [ Total Views: 2212 | Total Replies: 28 | Thread Id: 88745 ] |
Camo
A.k.a.: Kev
Threads: 209
| posted on February 14th, 2011 at 07:39 PM |
Price Drop - FS 2 x Italian 40mm Dellortos SOLD
Bought these a couple of years ago thinking of future blow through turbo setup and since bought a complete 2180 engine and the carbies are just
sitting around not being used.
I will try to put a photo up in the next day or two, but you know what they look like. I bought them off a running engine, but no guarantees that
they will be straight bolt on and run deal, but you could be lucky.
This sale is for 2 x 40mm Dellortos only, no manifolds or air filters (just 2 plain carbies).
They are 'Made in Italy' branded and I am not interested in boxing them up and posting, unless you make it worth my while.
$450 no offers. (EDIT new price at bottom)
Pickup in the Liverpool area - 2170.
Ph: 0413 135472, reply or PM me.
Thanks, Kevin
Camo
A.k.a.: Kev
Threads: 209
| posted on February 15th, 2011 at 08:46 AM |
Sorry guys, had the shits when posting this last night (long story).
Anyway, will post these anywhere in Australia at your expense. You pay postage when you pick them up.
Kev.
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
| posted on February 15th, 2011 at 05:20 PM |
Any idea on current jet sizes and venturies etc
Camo
A.k.a.: Kev
Threads: 209
| posted on February 15th, 2011 at 05:59 PM |
Thanks,
just had a look and the are 32mm chokes and jets are 52 & 142, hope you know what these all mean.
Cheers, Kev.
Camo
A.k.a.: Kev
Threads: 209
| posted on February 17th, 2011 at 10:06 AM |
Leaving myself open with this question, but am I asking to much for these.
I thought they would have sold quickly, maybe I will lose money
Kev
type3disease
Threads: 105
Mood: Average
| posted on February 17th, 2011 at 02:09 PM |
i dunno the difference between good bad or otherwise when it comes to carbs makes and brands etc
I guess if you can get a complete brand new kit with manifolds aircleaners etc for a bit more cash, people are likely to go that way
my 2c
Camo
A.k.a.: Kev
Threads: 209
| posted on February 17th, 2011 at 06:05 PM |
posted by type3disease
my 2c
Gee, that's a bit tuff. What type of twin carbs can you get as a complete setup (everything needed) for a bit more than $450 and will they have much
performance.
You also said that you don't know the difference when it comes to carburetors or brands and I guess I asked the question re price, but I thought it
would be from someone that knew what they were talking about.
Thanks for your comments, Kevin.
flipflopsurfer
Threads: 47
| posted on February 17th, 2011 at 09:33 PM |
It's difficult to say about price. I rate Dells as the best vw carbs, but idf's come a very close second and they are generally cheaper. On the
other side of the coin, you have an early and late carb, difference in inlet size, they look like a D & S sided pair, vacuum port for distributor
exists on one. To get them on a vw could be quite expensive, rebuild kits for both, jets, removal of the choke and add a cover plate, add 4 extra
studs for velocity stacks, buy stacks etc. They are euro carbs, rather than the CB performance imported ones, so bits maybe a little scarce, but
available in Europe easily.
type3disease
Threads: 105
Mood: Average
| posted on February 18th, 2011 at 08:23 AM |
sorry all I mean is I've not tried (run in a car) a pair of dell's then swapped it out for an aftermarket set etc etc... so haven't made a
comparison that way...
I'm sure like a lot of aftermarket stuff you get they might have their issues... but don't know that for sure... the empi, webber, hpmx stuff might
be awesome....
so for $500 you get a pair of 44's with the works - yes you'll need to cop freight but you'll be coping it all over the place as you start buying
manifolds, linkage, hardware etc etc
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D47%2D7319
no I don't think yours are particularily dear, but a lot of people might prefer to take the easier road than have to piece it all together...
just trying to answer your question...
so if they owe ya heaps - keep em and use em on something...
if you advertise them and no-one bites, then yes you need to decide to reduce the price, bump the ad, try ebay or keep em...
keep doing any or all of the above til they sell...
Aussie Dubbin
Threads: 90
| posted on February 18th, 2011 at 11:40 AM |
I'm pretty sure 500 carb kits are empi HPMX and are hit and miss type carbs. Alternatively i thinkyou can buy new carb kits including all hardware
for $1000, in Weber new stock, 40 or 44mm and get it jetted to keep costs down from them before shipment. There are numerous shops.
Not a bad deal is my 2c, but there are expenses if you went this way. I suppose you are looking for someone who already has all the linkage and
manifolds etc.
Camo
A.k.a.: Kev
Threads: 209
| posted on February 18th, 2011 at 06:28 PM |
posted by flipflopsurfer
On the other side of the coin, you have an early and late carb, difference in inlet size, they look like a D & S sided pair, vacuum port for
distributor exists on one.
Not sure what you mean by this as I had another look and on the underside there is what I assume is the month & year made and they are both
exactly the same and the serial number tag on them is only 1 digit difference. Hence they were made/produced at the same time, one directly after the
other. So they are not and early and late carb, sorry.
I hope this also help anyone else that me be looking at these. Make me an offer, I can only say no.
On a side note, Dellortos are the preferred carb for using in a blow through turbo setup which is why I bought them.
Kev
mountainbug
Threads: 34
Mood: allways wanting
| posted on February 18th, 2011 at 07:55 PM |
prob is mate, carbs only, no manifolds, air cleaners, linkages... good luck
flipflopsurfer
Threads: 47
| posted on February 21st, 2011 at 06:12 PM |
rnrnNot sure what you mean by this as I had another look and on the underside there is what I assume is the month & year made and they are both
If the tags match up, then 1 of the tops has been changed. The inlet banjo bolts are meant to be the same size, from the pics I'm seeing an 11mm or
early inlet and a 17mm or late inlet.
waveman1500
Also rides a Honda
| posted on February 21st, 2011 at 06:55 PM |
To answer your question, I would be in the market for these if they were a complete kit. Buying manifolds, linkages and air cleaners separately adds
up to huge dollars, which can approach the price of a complete kit. For example, a pair of new manifolds for these is roughly $270 plus shipping
depending on where you get them. For this reason only, I've decided that I'm not prepared to buy any carbs unless they come as a kit with everything
I need. I understand that there's not much you can do about this, but that's just my reason for not buying them.
Camo
A.k.a.: Kev
Threads: 209
| posted on February 21st, 2011 at 08:21 PM |
Now I know what you meant by different sizes, I thought you were talking about venturies or similar.
Waveman - Thanks for letting me know you are not going to buy them
Pumba
Threads: 255
| posted on February 21st, 2011 at 08:33 PM |
| Quote: | Waveman - Thanks for
69 Beetle
66 Beetle
56 Beetle
waveman1500
Also rides a Honda
| posted on February 21st, 2011 at 09:03 PM |
I don't get it. Did I say something stupid?
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
| posted on February 21st, 2011 at 10:08 PM |
I can understand people giving their 20 cents worth of opinion, but there seems to be lot of price based winging going on, send Kev a pm with an offer
if you think the price is not within your budget considering all the other related costs to make the Dells "complete".
As for comparing them to a "Kit" trust me, I've been there and these old Italian castings are far superior.
Air cleaners $46 cip1
Stacks $30 cip1
Linkage $75 samba
Manifolds $80 samba
Kit $35
Total roughly $266 plus purchase price of carbs still way below "kit" form with better casting and you will have to clean, set up and re-assemble
the carbs out of the box .
My 20 cents.
waveman1500
Also rides a Honda
| posted on February 22nd, 2011 at 07:05 PM |
That may be true fish26, but the OP did openly ask for reasons as to why people weren't buying them. I just wanted to help out by giving my opinion.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on February 22nd, 2011 at 07:19 PM |
$$$ price all good........no point "giving" them away
fish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
| posted on February 22nd, 2011 at 08:19 PM |
posted by waveman1500
sorry mate I am generalizing, it just seems like I am throwing you under the bus because your post was previous to mine.
baywindowbandit
A.k.a.: Mats J
Mood: laid back
| posted on February 24th, 2011 at 05:52 PM |
I agree with Hellbugged, the price is good, I just sold a pair of 36idf webbers, no linkages, manifolds or air cleaners and they sold for $450.
A bad day cruizin is better than a good day at work!
1. 1958 11 window project bus.
2. 1971 Beetle lowered on Empi 8 spokes.
Sydney NSW
Camo
A.k.a.: Kev
Threads: 209
| posted on February 24th, 2011 at 06:28 PM |
Thanks, there is hope yet.
Might whack them on ebay one day.
Kev
esevwbits
Threads: 143
Mood: alive!!
| posted on February 26th, 2011 at 01:27 PM |
Bargain price. anyone after some GOOD performance grab these. worth much more!
magos
Threads: 14
| posted on March 21st, 2011 at 09:54 AM |
Still available? Can you post them to brissie?
Camo
A.k.a.: Kev
Threads: 209
| posted on March 21st, 2011 at 11:26 AM |
Yes they are. How would you like to pay
Send me a PM and we can go from there.
Thanks, Kevin
Camo
A.k.a.: Kev
Threads: 209
| posted on May 24th, 2013 at 03:57 PM |
Hi all,
been a while since last post. These are still here and price drop.
Could have started a new post, but best to leave all the above chit chat there
Couldn't be bothered now and asking more and then have you bargain them down, so now $350 no offers.
Kev
0413 135472
4.01PM SOLD Pending payment on Sunday That was real quick !
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on May 24th, 2013 at 10:29 PM |
this is what happens when i work would of snapped them up.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on May 24th, 2013 at 10:31 PM |
posted by barls
So have you been working for the last 2years ?!
