[ Total Views: 1689 | Total Replies: 1 | Thread Id: 88787 ]
Author: Subject:  King Pin Reamer
MemberRyno17
Threads: 21
question.gif posted on February 16th, 2011 at 07:43 PM
King Pin Reamer
Just chasing up the size of the king pin reamer and do you need the exact VW tool?
Memberdangerous
Mood: 591
posted on February 16th, 2011 at 08:58 PM
I use a sutton adjustable reamer with a pilot.
Best results for alignment between both bushes mean that a pilot is best.
The king pin has a nominal size of 18mm for type 1.
http://www.sutton.com.au/Assets/1346/1/IPD05Adjustable_reamer.pdf
https://www.bolt.com.au/md-adjustable-reamer-tca-bright-p-96466.html
https://www.bolt.com.au/md-adjustable-reamer-pilot-p-96447.html
Also noteworthy is that the German king pin kits are much better quality,
and require less work for assembly that the brazilian ones.
Originally posted by westi
That's mad Alan.
