| [ Total Views: 1198 | Total Replies: 14 | Thread Id: 89187 ] |
1916baja
Threads: 176
| posted on March 10th, 2011 at 05:40 PM |
HP loss through generator/fanbelt?
Hi guys,
Just wondering if anyone has an idea on roughly how much power is gained by running an electric fan and different cooling set up on a small drag race
engine? Is it substantial enough to warrant looking into alternative cooling rather than the traditional generator fan and fan belt? Can you run a set
up like this with a magnesium case on pump fuel?
thanks
Mick.
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
| posted on March 10th, 2011 at 05:44 PM |
Mick ' i would personally not bother with this mod on a low budget car as it will lead to more drama's if not set up right especially for the bugger
all power gain
1916baja
Threads: 176
| posted on March 10th, 2011 at 05:48 PM |
Thats what i wan't to know.... How much do you really gain? is it worth doing....?
RISKY4LIFE
| posted on March 10th, 2011 at 06:26 PM |
every little bit it worth it for a race car!
waveman1500
Also rides a Honda
| posted on March 10th, 2011 at 06:38 PM |
If it's for drag and you're on a budget then just slip the fan belt off before each run and put it back on again in the pits to cool down!
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
| posted on March 10th, 2011 at 06:40 PM |
Michael , I have done dyno tests and with a std 7 1/2" size pulley you would gain 12 HP @ the wheels , or 9 HP with a 6 1/2" power pulley . This is
when you run an alternator and wide late fan , ROD .
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on March 10th, 2011 at 06:42 PM |
think its worth 6rwhp. Do the fanbelt thing.I got my setup cheap,as i didnt have a cooling system when bought the car so it was worth it.It never
gets driven except at the track.Not sure what it would be like on the street. Ruben tried it without much success. But as they say every bit helps.
What are you building?????
1916baja
Threads: 176
| posted on March 10th, 2011 at 07:09 PM |
Drag car project.... low budget. Not much different to how your rat started out really, although now yours seems to be getting the real race car
treatment! It needs to be finished in roughly 20 weeks so i'm gathering alot of info and parts then i'll pull my finger out and get some real work
done! It will never see the street.
OZ Towdster
Threads: 132
| posted on March 10th, 2011 at 07:18 PM |
Mick . just do what ever you want dude , as it's your ride .
Just like my rat everyone has there own idea's and i built mine to suit my tastes / uses , but just build it , don't stall on it for years as i have
done with the Towdster.
As your fist drag car build , feel free to give me a ring and i'll give you some advice that will ensure it at least makes Warwick
Andrew
whathaveidone
Threads: 98
| posted on March 10th, 2011 at 07:55 PM |
sweet!! you mean its only 20 weeks till warwick!!!! Good luck with it. Keep us posted
Gracey
Threads: 17
Mood: Itchy
| posted on March 10th, 2011 at 08:01 PM |
posted by RodPenrose
Rod, at what revs did you record these figures?
matberry
| posted on March 10th, 2011 at 08:32 PM |
Yes, I think rpm definately has something to do with it. I know of a dyno sesion earlier this week that saw 5 rwhp increase albeit at a lowish rpm (my
guess around 4600).
1916baja
Threads: 176
| posted on March 10th, 2011 at 09:10 PM |
posted by whathaveidone
Ha! no.... We are only in March! 20 weeks till the baby comes and i can't play in the shed for a long time!
oldskl60
Threads: 28
| posted on March 11th, 2011 at 06:35 PM |
| Quote: | Ha! no.... We are
Nah, you'll be right mate. Your wife will be that tired she will just go to bed and you go to the shed... but be warned you will have your balls
fried if you start your car...
BTW we only found a 3hp difference when we dropped my belt on Leons dyno. I am running a 5.5 inch alloy pulley and 12v generator.
whathaveidone
Threads: 98
| posted on March 11th, 2011 at 07:07 PM |
Its all good. My partner was due on sat and i still get shed time
