[ Total Views: 739 | Total Replies: 9 | Thread Id: 89284 ] |
phantom
Threads: 196
Mood: Where does this wire go?
posted on March 16th, 2011 at 09:09 PM |
Engine Fire - Advice On 'Condition'
Hi all,
Tonight my Beetle went up in flames, '64 model 1200cc with no mod's.
I caught it before it got too far, the following is damaged:
- engine
- engine bay
- engine lid (inside and outside)
- grille area above lid
- slight burns on the apron below the lid
Although very black and now covered in dry powder, a lot of the engine components still look complete. The fan belt is still intact, and there is
minimal easily locatable damage in the bay. The wiring above it (lid, for the plate light) is understandably melted.
The car will go for insurance assessment but I want to be prepared, in case I end up working on it.
Can someone please tell me what kinds of things to look for when checking serviceability of the various parts? For example the engine does not seem
to be siezed as the fan belt still turns the pulley, hoping this is a good sign. Where do I start with the rest of the components?
Thanks heaps.
Paulc1964au
posted on March 16th, 2011 at 09:12 PM |
really sorry about the fire do you know what the cause was? I know Adam and Mick at RAW are currently repairing a similar car and Adam did tell me
that it is difficult to repaint and area after it has been burnt.
PM me if you would like Adams number I am sure he will be able to advise you
phantom
Threads: 196
posted on March 16th, 2011 at 09:20 PM |
Thanks, where abouts is RAW? If you are able to PM his number I'd be appreciative.
Cause is unknown currently, I haven't fiddled in there too much as yet.
cesiumfrog
Threads: 7
posted on March 16th, 2011 at 09:22 PM |
hey bruce,
when i burnt mine it melted all the plastic/rubber components...ie fanbelt distributor cap and leads,rotor, fuel lines. oh..aircleaners (dual
carbies)
i respayed the engine lid and inside the engine compartmentand the black stuff washed and polished off elsewhere..didn't have any trouble respraying
burnt areas, normal prep.
pumped the water out of the engine and changed the oil and it was fine.
however all those bits do add up and paint,wiring etc ended up about $700
bet you were crapping your daks...i was.
phil
Paulc1964au
posted on March 16th, 2011 at 09:34 PM |
PM sent
oldtub356
Threads: 14
posted on March 17th, 2011 at 05:13 AM |
Bad luck, but it does happen to Dubs.
Mainly, relatively superficial - wiring, rubber stuff and paint - sometimes the Carby may melt.
Outside of fixing these bits, the engine should still be pretty happy to run.
The black stuff and the powder make it look worse than it is.
Most of the damaged bits, you will have accumulated over the years or can buy at SuperCheap - the painting being the biggest deal.
If you can paint it yourself - I would cost the parts and decide whether an insurance claim may cost you more in loss of bonuses than to repair it
yourself.
If you have or can get the parts, it should be a mornings work to get the car running again - not pretty yet, but a good start. And an opportunity to
replace all of those tatty old engine bits with nice new stuff.
Nice new wiring, hoses, rubber engine seals, maybe a coil, a bit of black engine paint - the body is a separate project - hell don't bother, you now
have a ready made RatRod. Don't shave, get an old John Deere cap on back to front, sneer at anyone that looks your way, a pair of widies on the back.
Hell, you don't even need to paint any flames on the car - you already have the authentic stuff. Those "PunchBuggy school kids will think that it is
soooo cool. I'm starting to think that this fire has been a good thing!!!
Anyway, not a big job. Just a few small ones.
Most of the dry powders are Borax based, so are water soluble and just hose off and aren't too dangerous (fish 'n frogs and termites don't like
it).
Oh, Dry Powder Extinguishers, $15 at Aldi this week!!!(March2011)
Also, a good argument for wearing a Fuel CutOff Valve alongside the gearbox - run off the ignition circuit(through a relay).
Don't be disheartened, keep the Bug - there are another 50 years in her yet.
Lance.
baja_01
Threads: 35
posted on March 17th, 2011 at 09:47 AM |
Something like this, might be a good idea for dubs..........Put the fire out without opening the decklid......
http://www.pegasusautoracing.com/productdetails.asp?RecID=7034
vwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on March 17th, 2011 at 10:15 AM |
the insurance company will almost certainly write it off, get the payout, keep the car and fix it, no probs with painting a burnt surface when you
sand it back to bare metal.
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
ian.mezz
Threads: 280
posted on March 17th, 2011 at 11:57 AM |
sounds like a write off.
the paint repair will cost heaps,
I had a customer who's 70 bug had a engine fire.
NRMA Wrote it off.
But the owner opted to keep the car and i did take engine out and replaced a fair few parts on the engine .
cost $1600
I WAS lucky to have a spare same colour engine lid.
baghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on March 23rd, 2011 at 06:41 PM |
baja_01 if he bajas it he will never need to open the lid again or repaint lid and apron.
My baja had a fire over the engine while in a workshop. It caused a lot of melting inside and outside but was repainted and it seems to be sticking
fine.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
