[ Total Views: 568 | Total Replies: 2 | Thread Id: 89398 ]
Author: Subject:  instrumentation
Member71dub
Threads: 46
Mood: happy
posted on March 22nd, 2011 at 06:32 PM
instrumentation
who can help .Ihave a 1971 super bug and am have some electrical problems.firstly when igntion is turned on the indicator light in middle of speedo has a dull glow.when hazzard light are operated the light works as normal .also when indicators are used light works fine.Also i have no generator warning lightor oil warning light when ignition is switched on have checked that correct wires are hooked up.what am i missing .car has new voltage reg and i have changed hazzard switch.any help would be appreciated .
Regards Barrie :fakesniff:
Memberwaveman1500
Also rides a Honda
posted on March 22nd, 2011 at 06:59 PM
Take it to a good auto electrician mate! Their services are worth it, and can be far cheaper than you would think. I've fixed a few electrical issues and usually think that I understand it fairly well, but whenever I get stuck, my local auto sparky will fix most issues like this for me with no hassle for under $200. Doesn't have to be a VW specialist or anything as they are extremely simple in electrical terms.
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on March 22nd, 2011 at 07:04 PM
Heres the wiring diagrams:
http://www.thesamba.com/vw/archives/info/wiringt1.php
vw wiring is very simple, just colour match and patiently follow. If u don't know whether a wire at the back is from a wire at the front, you can buy a cheap multimeter for $20 at dick smith and test continuity. that $200 could be 4 cases of grog! :)
(ô_!_/ô) (ô_!_/ô)
