[ Total Views: 810 | Total Replies: 7 | Thread Id: 8944 ]
Author: Subject: "flopping" a ring and pinion?
Membertype82e
Threads: 108
posted on July 30th, 2003 at 09:14 PM
Ive bought some split window reduction boxes to fit to my beetle i'm going to use the beetle gbox so I need to flip the ring and pinion.
it seems pretty straight forward but is there any tricks?
marcel
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on July 30th, 2003 at 10:26 PM
yeah I'd like to know too, for my Country Buggy resto. Do you have to do any shim/measurement work, or just flop it over?
Pay your debts, CxxT
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on July 31st, 2003 at 12:16 PM
Oh. So it's not a Saturday-afternoon-with-a-few-beers job then, huh
Membergeodon
Threads: 63
Mood: stumbling
posted on August 1st, 2003 at 07:25 AM
I'm FAIRLY sure that the chev corvair eng. spun the "wrong" way & this procedure would need to have been done for the VW's that were hot-rodded with this engine. There prob are none here but if you post this query on a USA site somewhere (samba??) you may find someone who has done it & who may offer some advice.
Membertype82e
Threads: 108
posted on August 1st, 2003 at 08:40 AM
why would you have to take out the pinion and reset the gears?
I would have thought you'd be able to take out the diff turn it around reshim it then put it back together?
marcel
MemberDesert Bug
Threads: 72
Mood: NOW VERY HOT AND HUMID!!!
posted on August 3rd, 2003 at 11:24 PM
Marcel I agree, check your other topic about fitting kombi axles.
Ian.
Membersplitbusaustralia
Threads: 65
posted on August 4th, 2003 at 08:51 AM
Flippin and a floppin
Position (pre load) of crown and pinion does have to be set in two dimensions. They have to be positioned so the sideways position is correct (shims each side of the diff carrier) and the longitudinal or fore-and-aft position is correct (shim the pinion).
When flipping the diff the manual recommends that the sideways position needs to be measured and checked (you need VW special tools for this) - I guess this is assuming the diff wasn't noisy in the first place though.
However, having said that, if the tranny is quiet (no diff howl) and works OK, about 90% still seem to be good of you just flip the diff carrier and the diff carrier shims. Bit of a pain in the ass if you fall in the other 10% though....
If you have access to the tools check it. If you don't and the trannies good just flip it (and the shims) and hope your luck holds?
RobK
Keep the faith!
Threads: 65
posted on August 7th, 2003 at 10:36 AM
having a blue
That's a good point! Although I blue as a final check after set up rather than during the setup process (although I do have the factory tranny tools...).
The best/cheapest/safest solution when flipping a diff carrier (and shims) and not having access to factory tools is to blue to check engagement of ring and pinion!
Good point!
RobK
keep the faith!
[Edited on 7-8-2003 by splitbusaustralia]
