| [ Total Views: 2404 | Total Replies: 5 | Thread Id: 89647 ] |
63baja
A.k.a.: Jade
Threads: 17
Mood: always annoyingly glass half full
| posted on April 5th, 2011 at 09:13 PM |
[FS - QLD] Offroad Rail buggy Mid Engine Subaru powered
Hi All,
My Mid Engine offroader is now finished and up for sale
(using proceeds to fund BAJA upgrade)
Buggy has an EA 81 subie engine and auto box Custom seamless tube Chassis Subaru Torsion bar rear, The list goes on.. This buggy has never been
offroad The BAJA has taken over as number one in the stable
I tried to attach pics but the files are to big ????
if anyone can help with that I would be greatful
you will also find it on e-bay under:
NEW" off road buggy 1.8L mid engine subaru Auto VW
Price is $4000 ono Buggy is located in Nanango Qld
contact details are A/H 41633931 or Mob 0437239658
Cheers Jade
An Inch of MOMENTUM is worth a mile of TRACTION
bluebaja
Threads: 77
| posted on April 6th, 2011 at 12:11 PM |
That is a sweet buggy. Well worth the asking price when you consider the cost of a chinese import and the hours that go into makng one from
scratch.
Good luck with the sale!
VDUBXTC
| posted on April 6th, 2011 at 03:26 PM |
http://cgi.ebay.com.au/NEW-off-road-buggy-1-8L-mid-engine-subaru-Auto-VW-/290...
63baja
A.k.a.: Jade
Threads: 17
| posted on April 6th, 2011 at 06:53 PM |
Thanks for the help with the pics and the link Jace
I'll obviously need to learn how to do all that tech stuff myself
and for the kind words bluebaja and yeah you're right I thought it was a very reasonable price
I stopped counting the cost long before it was finished and that's not taking any time into account my time at all
time doesn't worry me though doing this sort of stuff, I love nutting things out for myself
Hardly anybody who has seen it believes that I made it myself until they see the progress pics (I don't even have a shed!!)
can't wait to be able to spend a bit of money on the baja (when I figure out the pics thing I'll put some up.
I put some details below
The chassis was originally VW, I replaced the rear torsion tube with Subaru (so it has a built in height adjuster for the rear)
Rear trailing arms are modified Subaru, running subaru drive shafts,
Front suspension is vw Torsion bar
The main Chassis is made from Seamless tube 42mm O/D 3.4mm wall thickness
with the main smaller bracing made from Seamless tube 34mm O/D 3.0mm wall thickness
All joins are fish mouthed and all bends have less than 10% distortion
it has a 2.1 mm cheka plate floor
Rear chassis rails are easily removable to allow one man removal of both engine and gearbox (takes aproximately 15 minutes to have them both out and
on the floor)
All bolt used are 8.8 grade or better
Has a standard beetle fuel tank (aproximately 40 liters)
Front and rear shocks are new Toyota units
Subaru Disk brake rear and VW drums up front subaru dual circuit master cylinder
Collapsible subaru steering column
Moulded ABS BAJA / Sandrail seats with padded vinyl covers
4 Point 3 inch RPM Racing harnesses with quick release cam locks (Also has 5th point not fitted)
Engine is an EA 81 1.8 liter boxer four cylinder Rebuilt aprox 15k ago came from a one owner vehicle with 190k on the clock
Auto box is from the same car
It has a 40mm WEBBER sequential twin throat Carby and 3 inch pod filter
Custom made mandrel bend exhuast with high flow stainless muffler
Gemini radiator with thermo fan and large auto trans cooler
235/75/15 coopers on the rear and goodyear wranglers on the front
Has 300mm of ground clearance under floor
It fits onto my purpose built 8 x 4 flat top trailer
Wheel base is 2280mm front track is 1375mm rear track is 1550mm overall length is 3260mm overall width is 1795mm.
It took almost 2 years to build in total ( I am a welder by trade)
It was built with good quality gear specifically with durability and accesability of parts in mind
Calcool
Threads: 196
| posted on April 8th, 2011 at 11:34 AM |
Brilliant Work!
If I had a paddock that would be in it!
63baja
A.k.a.: Jade
Threads: 17
| posted on April 10th, 2011 at 08:15 PM |
SOLD
