[ Total Views: 478 | Total Replies: 1 | Thread Id: 90458 ]
Author: Subject:  Stock Front Beam Width
Memberaussie260z
Threads: 24
posted on May 15th, 2011 at 09:49 PM
Was wondering if anyone could help me out with measurements of the stock from Front Beam with Ball-Joints.
Just not 100% certain mine is a stock width because it looks like someone has installed Sway-A-Way type height adjusters into the top and bottom Front Beam...............so they might have also shortened it up a touch!
I took a measurement (See below)
http://i418.photobucket.com/albums/pp264/Aussie260z/FrontBeam.jpg
And was wondering if this is the stock width???
(This is not mine, just used for illustrative purposes.)
I came across information that said the stock Front Beam is 34 3/16" - Which works out to be pretty much 75mm wider than mine, but not sure if this is correct.
Anyone know what the stock width of the Ball-Joint Front Beam is?
Don't want to order the wrong Sway-Bar :-)!
MemberJohnnie B
Threads: 1
posted on May 19th, 2011 at 02:14 PM
A stock ball joint beam, measured along the lower tube between the towers is 31 1/4 inches. Which works out to be about 794mm
[ Queries: 40 ] [ PHP: 12.7% - SQL: 87.3% ]
