[ Total Views: 754 | Total Replies: 9 | Thread Id: 90498 ]
Author: Subject:  Rear Bump stops for IRS type 3 - installed
Memberbus914
Threads: 233
Mood: Could be worse
posted on May 17th, 2011 at 10:41 PM
The rear bump stops on my 70 square are shagged. There seem to be many aftermarket parts available. Is one better than another for a lowered car?
Style 1
Style 2
posted on May 17th, 2011 at 10:51 PM
Both links are the same stop, neither will fit your car
Memberbus914
Threads: 233
posted on May 18th, 2011 at 09:27 PM
sorry. this is the other link:
Style 2
Membergrumble
Mood: happy all the time
posted on May 18th, 2011 at 09:31 PM
If you want a couple of used ones see me at the Nat's. Cheers Les
posted on May 18th, 2011 at 09:40 PM
The new second one is the correct one for your car, but I'd recommend seeing Grumble at the nats, used og is way better than urethane pictured IMO.
Membervlad01
Mood: Side ways
posted on May 19th, 2011 at 10:45 AM
They are both incorrect for a late type 3. but the 2nd one is used on earlier type 3? I think, as that is what I have seen.
These are the right ones. Although still slightly different from stock.
and CSP list them the other way around to the early ones.
These are infact what late type 3 have and early one are like the 2nd one you posted. CSP list them the other way around lol
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=det&wkid=2...
71 notchback,
Memberbus914
Threads: 233
posted on May 29th, 2011 at 03:12 PM
I got some red ones
https://lh3.googleusercontent.com/-nDZTcquNyMA/TeHTPJhdR1I/AAAAAAAAluc/yOkHhrAl8w4/P1100825.JPGk
The helper softened them up a bit
https://lh3.googleusercontent.com/-x6rzHt3Owno/TeHTQitLT-I/AAAAAAAAluo/xuacP0QEVkw/P1100840.JPG
But the sledge hammer was still required to persuade them on.
https://lh6.googleusercontent.com/-t2iHFD-8lB0/TeHTR1wh7hI/AAAAAAAAluw/bVbvpJrsPss/P1100843.JPG
They fit well and should give a little more upward travel
https://lh5.googleusercontent.com/-mrPZe1kVFPU/TeHTPlwFYdI/AAAAAAAAlug/FG0GgZzploM/P1100832.JPGk
https://lh6.googleusercontent.com/-LxxH1NyVevY/TeHTQZizrjI/AAAAAAAAluk/RMf0tecqZSk/P1100836.JPG
Membervwo60
Threads: 71
Mood: good
posted on May 29th, 2011 at 03:39 PM
Any thing that is urathane and made by Empi won't last long, you are better of with a half worn out genuine part.
Memberbus914
Threads: 233
posted on May 29th, 2011 at 04:53 PM
Yes I know. but for the price I thought I'd just see how they fit.
Membergrumble
posted on May 29th, 2011 at 05:33 PM
Was the price better than free?:no::no: I did have a couple for for you if you had called. Cheers Les
