[ Total Views: 900 | Total Replies: 21 | Thread Id: 90771 ]
Author: Subject:  Qld Rego
Memberiwantamanx
Threads: 4
posted on May 31st, 2011 at 09:01 PM
Qld Rego
Can you get a swb manx regoed in qld with out pappers
posted on May 31st, 2011 at 10:39 PM
No
Membervwo60
Threads: 71
Mood: good
posted on June 1st, 2011 at 09:08 AM
Some people have and thats ok until there is a accident.
Member1916baja
Threads: 176
posted on June 2nd, 2011 at 07:36 PM
You can get it plated, my neighbour just did it. a simple inspection and a roadworthy and your done. I was under the impression they could no longer be registered here but I was very wrong.
http://i432.photobucket.com/albums/qq43/1916baja/BigAssWing22.jpg
Membervwo60
Threads: 71
Mood: good
posted on June 2nd, 2011 at 07:46 PM
Without the original approval to convert the beetle to a manx complete with a final inspection stamp they cannot be legally regested in Queensland. a lot of manx's do not have the approval and have been regested using dubious means,
Member1916baja
Threads: 176
posted on June 2nd, 2011 at 07:54 PM
I'm not interested in starting another manx rego argument but as far as i'm aware this is all legit, With QLD tansport documents to prove it.
Membervwo60
Threads: 71
Mood: good
posted on June 2nd, 2011 at 08:13 PM
So he must have the original approval to convert it, having a blue plate on the car does not prove that it is regested legally as a manx, this could be for some other modification that has been passed by a engineer. i have a manx with the correct approvals and have spoken to the main roads about getting it regested and as i said you must have the original approval to regester a SWB manx legally
Member1916baja
Threads: 176
posted on June 2nd, 2011 at 08:23 PM
no original paperwork, I think it has more to do with the qld transport document the engineer has given him.
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on June 2nd, 2011 at 08:40 PM
If it has previously in it's life been registered as a SWB Manx, then it can be re-registered as such. If it is a new conversion then it will require engineers approval. Shortened wheelbases are a tricky area, and not just a simple blue plate.
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on June 2nd, 2011 at 09:16 PM
ICV category, = mess :)
(ô_!_/ô) (ô_!_/ô)
Membervwo60
Threads: 71
Mood: good
posted on June 2nd, 2011 at 10:14 PM
The reason the main roads in queensland wants the original approval is because people shortened the pan in the back yard probably very poorly, the approval is the only record of the vehicle being shortened, rang a engineer at the Queensland main roads and was told that with no original approval i would not be able to register my manx legally, previous rego would only apply if it was registed as a myers manx, lucky i have all the original paper work,, next stop was shannons and asked them about insurance on the manx, i already have two cars with them, he stated that they knew a lot of cars ( not only manx's) that they insure do not have the correct approvals, but they were prepaired to accept there money until you have a accident, then they will simply ask you to produce the original approval to convert and a engineer's report for any other mods that have been carried out, with out it your insurance is void and you are on your own. if your neighbour has the paper work that approves the conversion in retrospect it would be of interest to a lot of people, maybe you could scan the document and post it here so other people can use it's contents to do the same
Member1916baja
Threads: 176
posted on June 3rd, 2011 at 08:25 AM
I'll have a look at it over the weekend some time, I think from memory it actually has a list of pre approved swb buggies on it.
Membervwo60
Threads: 71
Mood: good
posted on June 6th, 2011 at 02:00 PM
Hi, 1916BAJA, did you have any luck with the main road's approval. thanks
Member1916baja
Threads: 176
posted on June 6th, 2011 at 03:06 PM
Will go see him this arvo. Didn't get time on the weekend.
Member1916baja
Threads: 176
posted on June 6th, 2011 at 06:10 PM
He was not home this arvo, I'll try to catch him tomorrow.
Membervwo60
Threads: 71
Mood: good
posted on June 11th, 2011 at 09:34 AM
any luck yet with the document.
Member1916baja
Threads: 176
posted on June 12th, 2011 at 01:01 PM
Still trying to catch him, he hasn't been home all weekend.
Member1916baja
Threads: 176
posted on June 15th, 2011 at 05:50 PM
Finally got to see him, Here is the document he was given by the engineer.... The engineer has told him to take this document with him when he goes to the transport dept. The buggy now has engineering approval, and a roadworthy. SWB meyers manx. I am not saying, nor going to argue that this is a solution to getting manxes registered but this seems to be a legitimate way of doing it and it is currently working in his favour.
Member1916baja
Threads: 176
posted on June 15th, 2011 at 05:52 PM
Might wanna download it and zoom in... its a little hard to read.
MemberLovebuggy
Threads: 21
Mood: Making it happen
posted on June 16th, 2011 at 11:37 AM
The document above only specifies that the SWB Meyers Manx and other similar buggies are treated as ICV's but are exempt from fibreglass testing and beaming and tortional testing in QLD. All other ICV's are not.
This in itself with a Blue plate and RWC would not be enough.
http://www.meyersmanx.com.au
"More Smiles Per Mile"
Member1916baja
Threads: 176
posted on June 16th, 2011 at 03:08 PM
Does it not say that the blue blue plate with said codes are an alternative to an original approval letter?
Membervwo60
Threads: 71
Mood: good
posted on June 16th, 2011 at 07:13 PM
It say's that you can apply to the main roads dept for a new letter of approval if you have proof of previous rego, the vehicle would have to be regoed as a "IE" a manx on the rego papers when previous regoed, this would suggest that the manx had the approval but the approval has been lost, if it was not regoed as a manx i think the only way to rego it would be a ICV
[ Queries: 40 ] [ PHP: 3.0% - SQL: 97.0% ]
