[ Total Views: 538 | Total Replies: 0 | Thread Id: 91026 ]
Author: Subject:  F/S 2 Type 1 semi auto gearboxes and 1600 tp motor
Memberflux
Threads: 4
posted on June 13th, 2011 at 08:54 PM
1 off 1968 semi auto gear box working condition has torque converter, clutch servo and vacuum controller. 1 off 1971 semi auto gearbox jumps out of gear under acceleration, the clutch section has been disassembled and no oil in gear box. 1600 twin port motor needs rebuild I think it has thrown a con rod bearing, long motor without distributor, has spring plate and oil pump for the auto. Will not separate and pick up only.
$200 the lot.
Location Gladstone QLD 4680
phone Simon 0407586278
