[ Total Views: 618 | Total Replies: 5 | Thread Id: 91960 ] |
mjwcookie
Threads: 57
posted on August 4th, 2011 at 06:22 PM |
oil change in diff
I cannot find a drain plug in the diff bottom plate. how does one drain it, or do you have to take of the plate and let it spill. The refill plug is
the plug with the hex hole in it (like an enormous Allen key) on the side of the case? This would give an oil depth of a couple of inches, correct?
I assume you fill till it comes back out the filler hole?
All help gratefully received.
Mark
Mark Wilson
78 bay window, 82 bay Westy. T3 Caravelle GL 89 on the road.
Now in Victoria.
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on August 4th, 2011 at 07:12 PM |
should be a hex plug in the bottom of the transaxle (Gearbox /Diff) look again it might be full of muck or just fill it up I have never really seen
one with dirty oil.
Keeping it real !
mackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off
posted on August 4th, 2011 at 07:34 PM |
If it's a kombi box it is on the bellhousing.
Quote of the week
68AutoBug
posted on August 4th, 2011 at 07:37 PM |
Quote: | Originally
posted by mjwcookie
Mark
Hi Mark
THERE SHOULD BE A SIMILAR PLUG IN THE BOTTOM OF THE GEARBOX/DIFF TRANSAXLE...
i HAD TWO NUTS WELDED ONTO A BOLT to undo it...
and always take the side filler plug off first... so You know You can fill it... lol
and Yes the filler is the level... always put it in slowly as the oil has to flow into the differential section and it will back up and overflow if
poured in too fast...
what sort of VW do You have????
My semi auto beetle just has a large plate to undo...
as do most automatics...
68AutoBug
posted on August 4th, 2011 at 07:38 PM |
Quote: | Originally
posted by mackaymanx
that may be the answer.....
He has a 1978 Kombi
mjwcookie
Threads: 57
posted on August 4th, 2011 at 09:14 PM |
Sorry for not giving the detail. it is an 89 caravell GL auto. i have changed the trans fluid, now working on the diff. cant find a hex bolt or
recessed nut/plug on the bottom. Can only find one on the side. So would it be on the bell housing? I can look there tomorrow.
Thanks.
mark
Mark Wilson
Now in Victoria.
