[ Total Views: 2186 | Total Replies: 8 | Thread Id: 92056 ]
Author: Subject:  G50 adaption
Memberseagull
Threads: 752
posted on August 9th, 2011 at 07:21 PM
G50 adaption
what are the ratios in the gear bag ?
posted on August 11th, 2011 at 12:16 PM
Have you looked at Ricola's cabrio? He's using a G50.
I have to say though, it will be A LOT cheaper, easier to fit and almost as strong with a subaru trans. You won't need an adaptor plate either. It will also have the right ratios and LSDs and other hot up parts are more easily found. I spoke to Todd at the nats this year. I believe you can even use an early STi box which would be stronger still. The only reason I'd use a G50 is if I was using a porsche motor.
Member20bkombi
Threads: 26
posted on September 3rd, 2011 at 11:10 PM
Not out of the Question, you'll have to cut the torsion tube and the floor pan and body, I have a G64-21 in my 76 bus.
http://www.californiamotorsports.net/G50%206%20speed.htm
Any questions , just call. 0402233027 Aaron.
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
MemberBirdman
Threads: 49
posted on September 4th, 2011 at 10:09 AM
They are huge and heavy and you will have a hard time getting it engineered in nsw. And about $5k
posted on September 5th, 2011 at 10:54 PM
You'd have to say though, your's is up against some special challenges. :lol:
Seriously though, they are bulletproof.
Membervlad01
Mood: Side ways
posted on September 6th, 2011 at 09:26 AM
what about the early 930 box? they look like they fit better.
http://www.californiamotorsports.net/930.htm
71 notchback,
posted on October 3rd, 2011 at 08:08 AM
And only 4 speeds.
Membervlad01
Mood: Side ways
posted on October 3rd, 2011 at 12:55 PM
technically a 2 speed with 2 overdrives :spin:
those 930 engine have some serious torque to turn those gears.
71 notchback,
Memberttriebler
Threads: 16
posted on October 3rd, 2011 at 01:49 PM
Anyway....let me know if you want a 5 speed that fits without cutting to torsion tubes... :spin:
Reversed gears for Subaru transmissions.
Fit a Subaru 5 speed to your rear engined car
www.subarugears.com
[ Queries: 40 ] [ PHP: 13.2% - SQL: 86.8% ]
