[ Total Views: 1833 | Total Replies: 15 | Thread Id: 92327 ]
Author: Subject:  Done a head gasket in EJ22
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on August 26th, 2011 at 10:14 PM
The motor still runs sorta fine, just rough on startup with a bit of coolant smell out the exhaust. Then when it gets hotter, it runs better still, then starts overheating after 20 mins.
If I am to do the head gaskets, I would be wise to linish the surface of the heads also.
What success rate has anyone else seen from this procedure? I suppose just pop the heads off and check them with the side of a stainless steel ruler.
Memberseagull
Threads: 752
posted on August 27th, 2011 at 11:33 AM
The heads will be fine done many
posted on August 27th, 2011 at 12:16 PM
Too much boost Pete? hehe :smilegrin:
A.k.a.: Pete S
Threads: 312
posted on August 27th, 2011 at 03:35 PM
Trust it to go from bad to worse. I started it up today, and it ran rough for a minute, then started coughing and revving it was making it stall. I would say the plugs and maybe the oxygen sensor are fouled now.
Do they have to fully dissassemble the heads to face them?
Membervlad01
Mood: Side ways
posted on August 27th, 2011 at 09:52 PM
yeah coolant destroys o2 sensors almost instantly.
71 notchback,
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on August 27th, 2011 at 10:06 PM
not good mate, sorry to hear
the chaos project - click me
Memberrocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on August 30th, 2011 at 07:57 AM
http://www.ebay.com.au/itm/110734535763?ssPageName=STRK:MEWAX:IT&_trksid=...
A.k.a.: Pete S
Threads: 312
posted on August 31st, 2011 at 08:36 PM
I saw those heads. Got them.
What is the recommendation for top end VRS gasket set in Melbourne? We have an account with Bursons at work, so I will give them a call in the morning
I dunno if I should change the head bolts too?
If it was a turbo I would for sure. The workshop manual does not say you have to. Pretty cool tightening sequence.
Memberrocknrob
A.k.a.: Rob
Threads: 90
Mood: mystic
posted on September 1st, 2011 at 02:35 PM
yeah the tightening is a little weird...don't lose track!:smirk:
A.k.a.: Pete S
Threads: 312
posted on September 1st, 2011 at 09:01 PM
I got the heads. Bargain. They really are fully factory reco. 100% cleaned, machined, valves done. Look like new, oiled and plastic sealed with labels.
MemberElusiveStranger
Threads: 30
posted on September 10th, 2011 at 09:40 AM
You done it yet Peter?
If not, as Rob says - don't lose track when doing the bolts. Hang up the phone before proceeding.
posted on September 10th, 2011 at 09:53 AM
I can honestly say I've never encountered a more spastic head tensioning sequence than Subaru EJs have :crazy:
A.k.a.: Pete S
Threads: 312
posted on September 10th, 2011 at 11:43 AM
I haven't got a gasket kit yet. I have spoken to Clive cams, and they can regrind the cams to increase midrange torque. With stock ECU.
A.k.a.: Pete S
Threads: 312
posted on September 10th, 2011 at 01:18 PM
On Ebay there are head gasket and bolt kits from the US.
Memberchellejohno
Threads: 7
posted on September 10th, 2011 at 03:25 PM
i've been looking at them too, bloody cheap, but are they...cheap
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 14th, 2011 at 07:02 PM
Yo sent ya a pm ;)
[ Queries: 40 ] [ PHP: 18.4% - SQL: 81.6% ]
