[ Total Views: 705 | Total Replies: 3 | Thread Id: 92340 ] |
Old Hutcho
Mood: NSW Blues supporter to the end!
posted on August 27th, 2011 at 05:13 PM |
Plugs compatible?
I just changed the iridium plugs in my Falcon AU11 six cylinder Ford this afternoon, chasing an issue in that engine. I put a new set of NGK IGR5C
plugs in the engine, and it didint fix the problem.
So now Ive got a set of iridium plugs sitting on the bench which cost me an arm and a leg and they physically fit my 1916 VW aircooled engine with the
bigger heads.
Question now is, will they suit my 1916. They physically will screw into the hole. The reach is the same.
From the NGK site it looks as though they have the same heat range (5) as the plugs Ive got in the engine now (NGK B5HS).
Conversely, does anybody want a brand new set of iridium plugs for $100 incl postage to your place.
regards
Old Hutcho
Old Hutcho
posted on August 27th, 2011 at 05:25 PM |
Just a little further information to hand. The R stands for resistor. Whatver that means.
regards
Old Hutcho
68AutoBug
posted on August 27th, 2011 at 05:39 PM |
Quote: | Originally
posted by Old Hutcho
bigger heads.
regards
Old Hutcho
I don't know anything about iridium plugs apart from them being expensive.. lol
Both My CE Lancers 1997 & 2002 had normal plugs..
as MITSUBISHI didn't recommend Iridium plugs..
why I don't know...
Te R in the plug code means resistor so they have resistance in the stem of the spark plug.. this is to stop interference to radios TV etc
signals..
Modern spark plug leads also have resistance built into them...
for the same reason...
VWs have resistance [resistors[ in the rotor button and the
pieces that fit onto the spark plug leads...
with Your ford...
You could buy one long new spark plug lead that will fit all the spark plugs and replace one lead at a time with the new lead... that will tell You if
one lead has broken down...
not sure how many coils Your falcon has as one of those may be faulty too...
best to check everything with an ohms meter to see if everything g is the same or very close in resistance [ohms]
if a coil has a very high or low resistance then its probably the problem...
the silicone leads can be broken very easily inside...
I had a brand new one break just by pulling it off the coil...
You cannot tell by looking at the outside...
Old Hutcho
posted on August 29th, 2011 at 07:50 PM |
Well the problem turned out to be based on the leads. The leads apparently pack it in, the coil pack works over hard to get the spark to where its
got to go and the coil pack eventually cant handle it and packs it in. Laymans terms only.
Its a known problem with this model apparently. So. Ive still got 6 iridium plugs for which I dont have a use.
regards
Old Hutcho
