| [ Total Views: 1511 | Total Replies: 7 | Thread Id: 92629 ] |
crazyfiggi
A.k.a.: Alex
Threads: 138
Mood: lost
| posted on September 13th, 2011 at 10:46 AM |
Kombi dies when coming to a stop?
Hi everyone,
I've got a 77 van with the stock 2L twin carb engine.
For the last two weeks it's started with a strange problem, when I come to a stop at traffic lights etc the idle will drop way down, and sometimes
will stall, but if I give the throttle a blip it will go back to idling like it should.
Any ideas what this could be? I've checked for vacuum leaks, idle jets are clear and things like timing and points are all good.
Thanks,
Alex.
greedy53
Threads: 468
Mood: strung out
| posted on September 22nd, 2011 at 07:03 AM |
check your vacume hose to the break boster it may be leaking
SebastienPeek
Threads: 89
| posted on September 22nd, 2011 at 07:59 AM |
Could be your automatic choke.
Make sure the wires are plugged into the two solenoids, one found on the right of the carb and one on the left.
Then make sure all of the wires are plugged correctly onto the coil.
68AutoBug
| posted on September 22nd, 2011 at 01:25 PM |
posted by crazyfiggi
Hi everyone,
Thanks,
Alex.
sounds like the automatic choke is dropping down too low and when you press the accelerator the choke goes up a step and you get higher idling...
both chokes need checking and maybe adjusting..
or Your idle is just too low...
so both carbies need to be tuned again...
LUFTMEISTER
Threads: 119
| posted on September 22nd, 2011 at 04:56 PM |
Take your plugs out they will tell you,wet & black = choke. dry & white = air leak.
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on September 22nd, 2011 at 06:40 PM |
The idle air system operates off one carby and has tubes to both sides. Kind of like a parasitic idle system. Check it is operating correctly, and
smooth idle should be happening. People try to set idle by upping one or both sides, but it is the single idle air bypass that does the job smooth and
well.
crazyfiggi
A.k.a.: Alex
Threads: 138
Mood: lost
| posted on October 4th, 2011 at 05:57 PM |
Well i pulled the carbs off and found the throttle shaft on each side had HUGE amounts of play in them. I made up some new bushes out of brass and
rebuilt them. All seems good now!
Alex.
porrerahopeful
Threads: 4
| posted on October 17th, 2011 at 01:11 PM |
Those solenoids were always a problem........checked everything else until it was suggested I check them. No problems thereafter.
