[ Total Views: 1174 | Total Replies: 22 | Thread Id: 92715 ]
Author: Subject:  Hex key for diagonal arm
Membercam070
posted on September 18th, 2011 at 09:06 AM
I am about to pull apart the rear suspension (IRS 76 pan) and was wondering what size hex key I needed to remove the pivot pin for the diagonal arm. Can anyone tell me, or perhaps loan or sell me one?
MemberAussie Dubbin
Threads: 90
posted on September 18th, 2011 at 10:44 AM
17 mm mate very handy if you gat to buy one only about 12 bucks
MemberSides
A.k.a.: Dave Sidery
posted on September 18th, 2011 at 11:00 AM
Yup - like Aussie Dubbin says they're 17mm... same as the drain and filler plugs on the trans.
My toys
posted on September 18th, 2011 at 12:32 PM
a VW parts shop should have them for sale...
like VVDS in Sydney... ring first..
Threads: 559
posted on September 18th, 2011 at 05:42 PM
I have set of ratchet spanners that I bought from Aldi years ago. I have a cut off piece of 17 mm Allen key that I turn with ratchet spanner once its loosened, makes it much quicker.
Memberian.mezz
Threads: 280
posted on September 18th, 2011 at 06:34 PM
just go to autobarn, repco, supercheap and by a socket set, $50
http://www.myshopping.com.au/ZM--1215924632_HEX_SOCKET_SET_7_PC_MET_1_2_METRI...
:lol::crazy::lol::crazy::lol:
MemberLovebuggy
Threads: 21
Mood: Making it happen
posted on September 18th, 2011 at 07:30 PM
Meyers Manx Australia Sells them on line.
http://www.meyersmanx.com.au/17mm-Socket-Tool-38-Drive-Suit-transmission-and-pivot-bolts-P65.aspx#
"More Smiles Per Mile"
Membercam070
posted on September 18th, 2011 at 09:07 PM
Thanks for all the feedback guys. Appreciate it. Cheers!
Membercnfabo
Threads: 140
posted on September 19th, 2011 at 11:46 AM
i welded a 17mm bolt in the end of a socket.....
posted on September 19th, 2011 at 12:44 PM
Thats pretty much all I did.
Type 3 wheel bolt with a 17mm head welded to a M14x1.5 wheel nut
http://images.thesamba.com/vw/gallery/pix/787562.jpg
Membercam070
posted on September 22nd, 2011 at 02:28 PM
Thanks for the tip Lovebuggy. Arrived quick smart from Meyers manx. Now I am just waiting on the 6mm job to turn up so I can remove the drive shafts.
Cheers!
Membercam070
One day I will learn to weld........
But as always, Joel, the man with the answers.
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on September 22nd, 2011 at 03:16 PM
haha, I had a 17mm hex bolt head and welded it to a empirical spanner. worked like a charm :)
(ô_!_/ô) (ô_!_/ô)
MemberAussie Dubbin
Threads: 90
posted on September 22nd, 2011 at 06:30 PM
Just make sure you haven't got one of those 12 splined CV bolts like mine, have you cleaned one throughly? there were allen and 12 spline
Membercam070
posted on September 22nd, 2011 at 10:41 PM
Now you got me worried. Time for some serious degreaser.
Memberchillihilli
Threads: 19
posted on September 23rd, 2011 at 01:24 PM
Yep if it's a bug it should be 12 spline - Kombi's used the allen key bolt. If you have any trouble getting the 12 spline in you can bash a 6mm allen key into it and use that to turn it. One of mine I had to use that method and vice grips on the outside to get it. If this is the case plan to replace some bolts as it wrecks them. I ended up buying a full replacement set just in case. Take care of the little lock washer underneath too (or order some new ones).
cheers Peter.
71 Clementine Superbug Autostick
Membercam070
posted on September 23rd, 2011 at 03:21 PM
GRRRRRRR:grind: You guys are right, the CV bolts are of the 12 spline nature. Can anyone tell me what size 12 spline key I should order? I know a 6mm allen ket will fit it (sort of), but that doesn't really help.
Memberian.mezz
Threads: 280
posted on September 23rd, 2011 at 03:31 PM
mine just says M8 on the side of my 1/2 socket type.
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
posted on September 23rd, 2011 at 06:41 PM
Mine also says M8, as well as sidchrome, and a number - 14298. I don't know if that is a part number? I got it from Repco years ago.
From your ole' mate Jeff
Threads: 559
posted on September 23rd, 2011 at 10:36 PM
This is what I use for the 17 mm hex. Aldi ratcheting ring spanner and a piece of 17 mm Allen key. I use a socket or normal ring spanner to firist loosen bolt then this to unwind them quickly.
MemberAussie Dubbin
Threads: 90
posted on September 23rd, 2011 at 11:00 PM
From memmory its 8 mm 12 spline and a bugger to find just one piece. usually sold in a set may need to borrow oone
Membercam070
posted on September 24th, 2011 at 07:24 PM
I hope it's 8mm as I just bought one from auto one. My local has heaps of separate kinchrome tools and I also got a imperial socket to replace one I cracked. All about 10 bucks each.
Memberbeetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
posted on September 24th, 2011 at 09:24 PM
Here is the one I got from Repco a number of years ago.
http://i1202.photobucket.com/albums/bb364/Jeff_Walsh/Random%20VW%20photos/SplinedriveforCVBolts.jpg
[ Queries: 40 ] [ PHP: 3.3% - SQL: 96.7% ]
