| [ Total Views: 3096 | Total Replies: 13 | Thread Id: 92900 ] |
shaned
Threads: 14
| posted on September 29th, 2011 at 06:14 AM |
best paint for floorpans
Hi All
I have just put new floorpans in my baja .What would be the best thing to paint it with I am not going to have carpet as it is convertable and want to
be able to hose it out .
Thanks for any advise
Aussie Dubbin
Threads: 90
| posted on September 29th, 2011 at 10:36 AM |
2pk black or a rubber/ tar based sealent that hardens well
68AutoBug
posted on September 29th, 2011 at 05:01 PM |
posted by shaned
Hi All
POR 15 is best but You would need to use all their preparation stuff [comes in a kit]
otherwise You end up with a shiny black surface [the paint] sitting on top of the metal... lol
the paint sets hard as a rock... true...
You can hit it with a hammer... won't chip..
top and bottom of chassis...
stops rust too...
| Error |
MISS VDUB
A.k.a.: Ash
Mrs KOMBIBOB
Threads: 96
Mood: Low down and Dirty
| posted on September 29th, 2011 at 08:51 PM |
Rust Bullet
1962 Baja Beetle: "Peanut"
1968 Porsche 912 SWB: "Pip"
1972 Kombi Snail: "The Snail"
2016 Scirocco R: "Rocco"
shaned
Threads: 14
| posted on October 8th, 2011 at 08:19 PM |
I have found the stuff i am going to use gator gaurd. It is a spray-on ute linner .just spray with a swartz gun .It is like rino linning but
diy it is extreamly hard and fully waterproof so will stop rust . It is available at automotive paint supply cost $250 for a 4l kit . can be applied
very thick if needed .And will work as a sound deadener.
h
| posted on October 8th, 2011 at 10:43 PM |
show us before, during n finished pics pls
snitz
Threads: 37
Theme: UltimaBB Psyche Red
Mood: "Bug"gered
| posted on October 8th, 2011 at 11:08 PM |
Yep like someone else said KBS Rust bullet system..Australian made,same quality if not better than POR15 and cheaper..Plus it comes in other colours
than just black.
DubCrazy
A.k.a.: steff
| posted on October 9th, 2011 at 07:28 AM |
posted by shaned
allthough that stuff is good it is not a good idea to use it on ur floorpan
its a rubber based product,yes it goes hard but if you chip it which you will being under the car the water will get between the liner and the floor
making it lift with out you knowing it.
great in a tray but not for the underside of a floor...
steff........
shaned
Threads: 14
| posted on October 9th, 2011 at 08:15 AM |
yeh i`m not using it under the car i am doing inside the car with it as it`s a convertable baja and i wont be using carpet it will stop from getting
scratched and allow me to hose the inside out i will use a tar based spray for underneth
vwbugsrule
Threads: 26
| posted on October 9th, 2011 at 11:54 AM |
POR 15 is great!
Imac
Threads: 0
| posted on October 14th, 2011 at 09:27 AM |
I am a Rhino linings applicator. It is a spray on 2part polyurethane, KBS and POR15 are solvent based polyurethane paints. I would assume that Gator
guard is a polyurethane as well, $250 for 4ltrs is very expensive, I charge about $750 for a ute tray and apply it 4mm thick which is about 17-18 ltrs
of product which is less than the material cost if you were to apply gator guard to the same thickness. Hippo liner is a cheaper alternative at $99
for 4ltrs. But remember anything solvent based is not as strong as a raw polyurethane due to the solvent breaking down the polymer chain which will
not be fully restored when the solvent evaporates. I have coated the chassis of my buggy top and bottom to use as a demo, I got a bit carried away and
coated the body as well. I thrash this buggy offroad and on the beach I wipe it clean just like a teflon saucepan. As far as chipping, I can only
speak for Rhino. It is virtually impossible to chip it is to flexible. I've seen it cut, I've seen it de-laminate due to poor surface preparation
but never chip. When I demo Black Betty (my buggy) I hit it with a hammer with no fear of damaging the Rhino, mind you I have to be careful not to
smash the fibreglass or dent the steel underneath. I have coated several chassis in both POR15 and KBS and both are excellent (as far as paints go)
but I think KBS sticks a little better.
Cheers Ian
PS My web site http://www.rubberystuff.com.au/
shaned
Threads: 14
| posted on October 17th, 2011 at 05:11 PM |
where do you get the hippo linner from that price sounds good .
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
| posted on October 17th, 2011 at 07:53 PM |
I have seen it on Ian's buggy - it certainly looks the goods.
From your ole' mate Jeff
Imac
Threads: 0
| posted on October 18th, 2011 at 07:58 AM |
Supercheap auto
