[ Total Views: 580 | Total Replies: 4 | Thread Id: 92946 ] |
shaihulud
Threads: 197
posted on October 2nd, 2011 at 10:10 AM |
Ball joint brakes to king pin
I'm in the process of building a buggy on a 1958 king pin pan.
The brakes need a complete rebuild.
I've fitted a 1970 swing axle gearbox, 4 bolt wheels, to the rear and I want the front wheels to be the same.
Can I fit 4 bolt, ball joint drum brakes to the front easily? I realise that some machining may be necessary.
I also have a set of ball joint disc brakes. Can they, with some machining, be fitted to the king pin front end? Of course I'd prefer the disc bakes.
grumble
Mood: happy all the time
posted on October 2nd, 2011 at 12:11 PM |
Give Richard a call at V Force,he has a good knowledge and I possibly the parts required.
vwo60
Threads: 71
Mood: good
posted on October 3rd, 2011 at 07:09 AM |
You will need to have the outside bearing bore machined to a larger size, there is a tappered roller available that will then fit the stub axle,
brackets are commercially available to fit the caliper to the link pin stub axle. you will need to fit a dual circut master cylinder and have the
conversion approved, this is quite a common conversion.
shaihulud
Threads: 197
posted on October 4th, 2011 at 09:40 AM |
Thanks vwo60, That's what I thought I could do. I have the parts, a bracket to support the caliper is readily available and with a little machining
it will be done.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on October 4th, 2011 at 10:04 AM |
i have the bearing part numbers if you need
