[ Total Views: 615 | Total Replies: 4 | Thread Id: 93494 ] |
vwbugsrule
Threads: 26
posted on October 31st, 2011 at 11:07 AM |
Engine does not turn over
Hey guys, I have finished my engine and i want to crank it over to start it and see if it works. I charged up the battery, connected all the
electricals and gave it some fresh fuel. I turned the key and the engine hardly turns over. I removed the spark plug and it turns perfectly fine. The
starter motor was perfectly fine before and same with the battery. So what is stopping the starter motor so turn the engine over ?
Hope you can help.
Joel
posted on October 31st, 2011 at 11:49 AM |
If you had to charge up the battery I'm guessing its been sitting low on charge for a while?
if so there's your problem
vwbugsrule
Threads: 26
posted on October 31st, 2011 at 01:32 PM |
Yes it has been sitting around for a long time uncharged... damn ok thanks for that.
greedy53
Threads: 468
Mood: strung out
posted on October 31st, 2011 at 07:50 PM |
first thing to do is borrow a battery before getting all upset the battery if no good it would have had no worries winding over the worn out motor now
it is showing it's age
vwbugsrule
Threads: 26
posted on October 31st, 2011 at 08:29 PM |
The problem was the charger, it said the battery was fully charged, So obviously you would think it is charged, but it actually wasn't. I then tried
a different charger which said the battery had 25% charge, so i charged it up again to 100% and she turns over now I will start it up tomorrow.
