| [ Total Views: 2189 | Total Replies: 15 | Thread Id: 94012 ] |
jack schoot
Threads: 38
| posted on November 26th, 2011 at 05:39 PM |
MY NEW RIDE ARRIVED TODAY
My new dub has arrived today. its a 1961 50/50 with flash trim , original radio , sunvisor
all dealership fitted accessories. it did have the original flying vw logo fitted on the hood but was stolen.has only surface rust. car has lived at
orange / bathurst area all its life, has not been registered since 1981.
Would anybody know of the numbers built in 1961 or is there a register
happy chappy, man !
| Error |
| Error |
| Error |
bugsandoil
Threads: 17
| posted on November 26th, 2011 at 07:44 PM |
LOVE it
Fantastic score
Matt Ryan
A.k.a.: Matt Ryan
Mood: Fweemin
| posted on November 26th, 2011 at 10:48 PM |
Very Nice,
Mines a 61 too,
According to the Club Vee Dub websites history page 14,970 1200cc Beetles were sold that year.
24,388 in '60
14,970 in '61
21,273 in '62,
20,135 in '63,
22,293 in '64,
18,077 in '65
Then downhill from there.
You could probably put the drop in '61 down to the introduction of the new 40 Hp engine, the market wanted to "wait and see" I guess. I think there
might have been an economic downturn that year too.
What month was yours produced? There are a few differences from the early '61 to the late '61. There would also hve been '61s still being sold when
the next model came out with all sorts of add ons and discounts to get rid of them. ( basically a good time to buy a beetle if you had the cash)
Pics are when I first went to look at buying it, lots of incorrect stuff to be seen.
The reason it has all those dealer fitted accessories is because that was a VERY slow selling year and the dealers did whatever they could to shift
them.
Things you should guard with your life:
50/50's:
If they are in good nick, keep them out of the sun as much as possible, they fade and craze terribly and you cannot replace them (except second hand
and they will probably be worse than you already have). Last pair of new old stock I saw about 2 years ago went for 350 Euros. (Italy used them for a
couple of years just like we did). At the time the Euro was a bit more than double the Aussie Dollar.
This is what they look like after too much sun.
The housing to guard seal is also no longer available as is the lense to chrome trim seal so, treat them gently, or you will have to get inventive and
come up with something else to do the job.
The tail light housing body tends to rust out underneath and undoing the mounting nuts often breaks off the stud that holds them in place. Be very
gentle with them. If WD40 doesn't do the trick, I've heard eucalyptus oil works a treat. You really need to remove the housings and treat them for
rust and then add some prevention. If they're not bad yet they WILL get there.
Once re-fitted clean the drain hole at the bottom of the housing regularly to stop water accumulating behind it.
While you have the housing bodies off it might pay to make a paper template of the mounting holes in relation to the main body of the car as they are
different to every other Beetle model (in case you ever need to replace a guard, or help out another veedubber).
You could consider adapting some '62 & 1/2 and later rear lights for general use and putting your 50/50's on for special occasions.
Number plate mounting bracket:
Rare as rocking horse shit. Most Beetles these days have the number plate screwed directly to the deck lid. There have been reproduction ones over the
years but they are not the same quality.
Flash Kit:
Still available second hand and repro's too. The thing with originals is the metal clips rust out and new replacement clips are not available.
Repro's are a different size. Remove your door trims and rear quarter trims so you can squeeze the clips to release the trim (the front bits are easy
access under the boot lid).
Remove all the clips, clean them up with some rust converter and soak them in some fish oil then let them dry and re-fit them. You could seal them
with silastic from the inside as they tend to rust more where they make contact with the hole where they go through the body panels.
While you have the trim off it might pay to make a paper template of the mounting holes in relation to the stock trim in case you ever need to replace
a panel or help out another veedubber.
Fuel Tank:
The 1960 model has the hump style tank similar to earlier models whereas the 1961 has the flat style used from then on.
The BIG difference is it's the only flat tank model that has the filler on the passenger side of the car. That makes it replaceable only by a second
hand one, from a very low production year. So, it would be a good idea to get your tank cleaned and sealed . There are kits you can get to do this,
POR 15 and others make a fuel tank kit, or there are places where you can get your tank done professionally.
That's all I can think of for now, I'll add more if the grey cells allow.
Regards,
Matt.
bugsandoil
Threads: 17
| posted on November 27th, 2011 at 05:02 PM |
so I forgot to ask,...
How and where did you find this one???
(I know 'where' location,.. I'm asking where was it advertised.)
jack schoot
Threads: 38
| posted on November 27th, 2011 at 05:45 PM |
i purchased it from a fellow called peter , i purchased a beetle from him 3 years ago and regretfully sold it.i called him a few months back and he
told me he had this one. he buys a few vws around his area. if you need his number i can pass it on to you, he has all sorts of bits and peices to
suit a veriaty of vws.
i put some 2 pac buffing cream and used a FOAM BUFFING PAD with water on my tail lights today and they come up fantastic.
bens1964vw
Threads: 32
| posted on November 27th, 2011 at 08:43 PM |
That is beautiful.
t_tuffnut
Threads: 70
Mood: Rust free for 12 months
| posted on December 9th, 2011 at 10:52 AM |
Looks awesome! If you need any help I recommend VW Performance at west gosford. Liong and James are a font of information and advice And a good place
to go for spares.
davidr
| posted on December 14th, 2011 at 05:49 PM |
nice score..
ragged
A.k.a.: David
Just ask if you need HELP!
Threads: 46
| posted on December 15th, 2011 at 11:18 AM |
Does it have a fuel guage?
Does it have a fuel tap under the dash?
Cheers Dave
BUGBOY
Chief Toy Dude / Head Cruiser
Threads: 403
Mood: A wise German once said
| posted on December 15th, 2011 at 08:18 PM |
looks real nice, good score!
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Pumba
Threads: 255
| posted on December 17th, 2011 at 07:29 AM |
posted by ragged
Cheers Dave
Jack is no longer a member here, it does have a fuel gauge and no tap under dash.
cheers shane.
69 Beetle
66 Beetle
56 Beetle
ragged
A.k.a.: David
Threads: 46
| posted on December 17th, 2011 at 09:27 AM |
| Quote: | Jack is no longer a
cheers shane.
Was he pushed or did he jump?
Pumba
Threads: 255
| posted on December 17th, 2011 at 10:56 AM |
A bit of both i think
69 Beetle
66 Beetle
56 Beetle
ragged
A.k.a.: David
Threads: 46
| posted on December 18th, 2011 at 10:10 AM |
Come back Jack...We all have good days and we all have our bad days.
Aussie Vee Dubbers is like that girlfriend that you just can't live with, but the sex is great!:
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on December 18th, 2011 at 10:51 AM |
Please come back jack.
vlad01
Mood: Side ways
| posted on December 19th, 2011 at 08:18 PM |
posted by ragged
well that means I have been having one hell of an affair with the samba
71 notchback,
