[ Total Views: 1322 | Total Replies: 13 | Thread Id: 94367 ]
Author: Subject:  Fire extinguisher location in a Beetle
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on December 17th, 2011 at 08:45 PM
I have a 1kg fire extinguisher that I have procured, and I am wondering what locations people have fitted them? I have decided that the passenger floor just in front of the seat is good. It gives access for driver and passenger, and is out of the way. The positions on the side of A pillar and under dash looked to be in the way.
I am not planning on using it, it is just cheap insurance. I already have all fuel lines and fittings secure and renewed in the engine bay, and fuel filter fitted up under near fuel tank.
MemberSpecial Air Service
Chief "Gunna"
Threads: 210
posted on December 17th, 2011 at 08:59 PM
Pete, I fabbed up a bracket that fits the extinguisher to the seat frame just behind my feet. That way it moves back & forth with the seat. got the idea from a porsche website.
Brendan
[size=5]
Click Below
[/size]
[size=6]
Mid North Coast VW
[/size]
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on December 17th, 2011 at 09:49 PM
mines on the tunnel in front of the gear stick
can get a pic tomorrow if you want
the chaos project - click me
posted on December 17th, 2011 at 11:35 PM
I just copied other people and placed it front of the gearshifter
I have seen others located just inside the LHD...
which is much better than in the boot....
in front of the seats sounds great.....
posted on December 18th, 2011 at 07:23 AM
Late beetles with the 3 point mount have a nice place on the front support
You cant sort of see mine here
http://i35.photobucket.com/albums/d170/blue74l/Marty/103_2290.jpg
MemberAyeBee
Threads: 18
posted on December 18th, 2011 at 12:17 PM
Mines on the passenger side A pillar, doesn't seem to get in the road.
A.k.a.: Pete S
Threads: 312
posted on December 18th, 2011 at 03:41 PM
I put it in the spot where Bizzare has his. I didn't want to drill holes in the original floor mat on the tunnel.
I have just drilled two holes in the plate in front of the seat runners. I have to take the extinguisher out to slide the seat out, but I don't take the seat out very often.
MemberannosL
Threads: 43
Mood: need to win lotto
posted on December 19th, 2011 at 01:24 AM
I've heard horizontal is better than vertical to keep the powder loose, is that dinkum?
posted on December 19th, 2011 at 07:14 AM
I'd say...yep, fair dinkum.
Also good every 6 months or so to remove from holder and give the extinguisher a shake for the same reason.
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on December 19th, 2011 at 07:43 PM
Or take it for a nice strap offroad. That's sure to shake things up! :lol::lol::lol:
SMiley :)
posted on February 24th, 2012 at 10:20 AM
having it in front of the gearshifter means its shaking the extinguisher up every time You brake.. lol
I have found that some of the newer fire extinguishers aren't really made to be mounted in a car as their holding method isn't too good. plastic instead of metal..
very flimsy and some are very difficult to undo..
MemberAA003
A.k.a.: Phill
Threads: 39
posted on February 24th, 2012 at 10:51 AM
Brendan
That's where the genuine VW brackets fit. I have one but it doesn't fit Transporters.:(
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!:lol:
MemberBiX
Threads: 154
posted on February 24th, 2012 at 01:00 PM
You can buy ones with twin metal straps. they are aimed as the CAMS requiremtns.
I prefer the passenger footwell. If the straps become loose and its on the tunnel in front of the gear shift, it may fall around the pedals......
Go hard or go home!!!!
posted on February 24th, 2012 at 02:06 PM
I have seen some cheap ones that are held to a bracket [plastic?] with what looks like some sort of cable tie, but You can brake it with Your hands.. so that doesn't sound good if You are upside down and the extinguisher is above You!!!
or whether they will stay put if You are hit side on by another car...
after all this... I may go and check mine again.. and maybe stick an extra strap over it...
You can get the metal top part extinguishers refilled...
they don't do the ones with plastic tops and triggers etc...
[ Queries: 40 ] [ PHP: 17.9% - SQL: 82.1% ]
