[ Total Views: 779 | Total Replies: 10 | Thread Id: 94681 ]
Author: Subject:  CSP Tube for Accelerator Cable through fanshroud
MemberBeetleJuice
A.k.a.: Craig Paton
Threads: 37
posted on January 9th, 2012 at 11:31 AM
Does anyone carry CSP here in Aus.............. I am after part no 129 893 113A
IF not I will order myself from CSP.
Craig
FringeDweller
posted on January 9th, 2012 at 12:16 PM
DOnt believe anyone carries the full range
CI have seen limited stuff at both Classic and Vollks
Can I ask what the benefit of the CSP tube is??
Membergrumble
Mood: happy all the time
posted on January 9th, 2012 at 12:18 PM
Why not just make one it is only a 10mm tube with a flange to stop it slipping through?
MemberBeetleJuice
A.k.a.: Craig Paton
Threads: 37
posted on January 9th, 2012 at 02:10 PM
The CSP tube is quality, and they work.......except if one trimmed too much off the one he bought in the first place and the flexible cable doesn't cover the tube at the back of the engine.:fakesniff:...So then one has to buy another and measure and trimm off 6mm less than the 1st!
On a side note:
The CSP Bellcrank linkage works beautifully!
FringeDweller
posted on January 9th, 2012 at 02:33 PM
Originally posted by BeetleJuice
On a side note:
Gotta agree there!
Have had one on for about 2 months
I wont touch a hex linkage again
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on January 9th, 2012 at 04:25 PM
oh dear :sniffle:
did you see the ones on the samba that have a small roller wheel for the cable on the engine bay side?
i'd be giving them a try if say, i stuffed with mine and had to get a new one :kiss:
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on January 9th, 2012 at 09:32 PM
We do try and carry a decent amount of stock of CSP parts however unfortunately no accelerator guide tubes currently.
http://dasrestoparts.com.au/catalogsearch/result/?q=csp
Daimo, I think I have a couple of those roller wheel guide tubes in amongst my own stuff if you want to try one.
Al
Memberhellbugged
A.k.a.: Daimo Pell
posted on January 10th, 2012 at 06:03 AM
yeah cool Al.
i didn't know you carried CSP, so that's cool........i ordered a roller tube after i posted and was thinking they probably not the go for what Craig is needing, but i guess he will let us know.
http://www.thesamba.com/vw/classifieds/detail.php?id=786740
posted on January 10th, 2012 at 07:19 AM
Those roller tubes are the go for a crossbar linkage, nice to hear your stocking them Al, I'm thinking a Berg linkage doesn't have the need for one as they don't have the cable alignment issues that you get with the crossbar style.
MemberBeetleJuice
A.k.a.: Craig Paton
Threads: 37
posted on January 10th, 2012 at 07:59 AM
I'll stick with the CSP tube as like Matt said, if you don't have alignment issues.
From reading on Samba, the roller is designed for the crossbar linkage.
I know when I get the tube length right, the CSP will be even smoother. The flexible cable is sitting too low and there is a little drag. I can feel it through the pedal.
FringeDweller
Memberbushed
Threads: 66
posted on January 10th, 2012 at 12:52 PM
your drag may also be inside the chassis coduit wearing a groove and cutting the conduit???
