[ Total Views: 632 | Total Replies: 6 | Thread Id: 94965 ]
Author: Subject:  Bug too low to get on drive - need ramp suggestions!
Membervorsprungdurchtechnique
Threads: 21
posted on January 23rd, 2012 at 09:43 PM
Just moved into a new house and the drive is too high to get my low bug on, I need a long-ish gradual ramp to drive up. I'm thinking ramps like you would find on a back of a trailor - but I dont want to spend loads of money. Anyone got any bright ideas where I might find something like this?!
And no, raising the bug is not an option! Heavy rains are coming and I gotta get the bug inside.
Thanks!
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on January 23rd, 2012 at 10:15 PM
Post a couple of pics of your drive to give us an idea of what needs to be done.
Memberwaveman1500
Also rides a Honda
posted on January 24th, 2012 at 09:51 PM
Do you want it to be temporary or permanent? If it's only temporary, then a few bits of wood will do the job. For a more permanent solution, a big steel plate will work.
posted on January 25th, 2012 at 01:30 AM
Thanks!
A local house used to have 2 metal plates about a metre long
on their driveway... between the driveway and the concrete in the carport.... it was bolted in with 4 bolts...
it looks to be only about 25mm high difference in the concrete.. maybe it was a bit more....
Memberjamiesc
Threads: 106
Theme: UltimaBB Pica Red
posted on January 25th, 2012 at 04:42 AM
can you borrow some ramps of a friend or even motobike ramps would to or a thick peice of wood
my friend has a steep driveway also if you have a footpath drive your car on the foot path then hook
it hard thats always work for myself
jamie
MemberBEETLE CRISIS
Threads: 1
posted on January 25th, 2012 at 02:49 PM
3 round pipes welded together large medium and small.
Member5lam
A.k.a.: Dave
AKA: BlackBug
Threads: 38
Mood: Slammed
posted on January 26th, 2012 at 09:45 AM
Air shocks.....
[ Queries: 40 ] [ PHP: 2.8% - SQL: 97.2% ]
