[ Total Views: 545 | Total Replies: 5 | Thread Id: 95087 ] |
kombibob
Threads: 173
Mood: at by cows
posted on January 29th, 2012 at 09:57 PM |
mk2 8v starts but wont run??
Hi Guys,
Was driving the Mk2 today it was running fine but after grabbing a feed we jumped back in and found it would no longer run??
Engine turns over, starts, runs for a few seconds and dies, both pumps seem to be working and seems to be getting plenty of fuel to the rail.
We got it towed home tried it again and it was the same but after a few attempts i had it running and revving fine for a few minuets but it ended up
stalling and going bad again. Even changed the fuel filter out in the rain tonight with no luck.
We have had a couple of weeks of wet weather so starting to think elec gremlins.
Any ides??
_________________
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
matberry
posted on January 29th, 2012 at 10:09 PM |
sounds like fuel pump, doesn't the Mk2 have a lift pump in the tank, they were trouble 10 years ago.... or is that a mk3?
Efi fue pressure has to be exactly right, check pressure and if incorrect, can be pump or regulator.
kombibob
Threads: 173
Mood: at by cows
posted on January 30th, 2012 at 09:01 AM |
Hey matt, yep lift pump is working, but I will test pressure after work to make sure.
1961 swb buggy
1960 karmann ghia
kombibob
Threads: 173
Mood: at by cows
posted on January 30th, 2012 at 05:07 PM |
well came home to work on the bloody thing but in true Volkswagen fashion the problem seems to have gone??
Started and ran straight away so i took it for a run and it didnt miss a beat. but i did notice a dirty fuel kind of smell from the exhaust while
idling just after the first start up.
So now thinking water in fuel??
1961 swb buggy
1960 karmann ghia
greedy53
Threads: 468
Mood: strung out
posted on January 31st, 2012 at 05:25 PM |
dont know if anyone will believe me bu tit worked for me after my dad told me about iti once had amy share of water in my tank so i poured a bottle of
metho in and never had anymore problems wont work with a guts full of water but it did work and only cost me $2.00 mit be worth a try
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
posted on January 31st, 2012 at 06:22 PM |
Check the earths too bob as if it's got a loose or dirty earth some where the ecu won't like it much which will cause intermitant faults
