[ Total Views: 3436 | Total Replies: 23 | Thread Id: 95253 ]
Author: Subject:  Steering box rebuild kit
Membertelf
posted on February 8th, 2012 at 06:47 PM
I have 3 old German type 1 steering boxes, all of them with play I'm looking to rebuild the best of the 3 and wondering if and where i can get the parts. i bought a brand new 1 a few years ago and have had nothing but trouble at first it was tight the and now is as bad as the old German ones.
Thanks Telf
posted on February 8th, 2012 at 06:49 PM
What year models
Membertelf
posted on February 8th, 2012 at 06:59 PM
Sorry its for a 71 type 3, So the latter 1
posted on February 8th, 2012 at 07:14 PM
I dont think theres any Type 3 kits around
But ring VVDS 02-9789-1777 they will know
It would be strange if they are worn is the adjusting screw all the way in ???
Member69bug
Threads: 24
posted on February 8th, 2012 at 08:13 PM
is rebuilding them the best option..
mine has a click in it
1969 1500
Memberpsimitar
Threads: 148
posted on February 8th, 2012 at 11:17 PM
Try T3D in the UK. Good website n they specialist in T3s. If similar to a T1 box then only the worm gear is available but bearings should be able to be sourced from a bearing supplier as the originals are FAG.
posted on February 9th, 2012 at 07:33 AM
Beetle and type 3 steering box are the same.
Membertelf
posted on February 9th, 2012 at 08:47 AM
Sorry should have mentioned that Type 1 & 3 are the same.
Think i will give vvw a call today and find out what is available.
Membervlad01
Mood: Side ways
posted on February 9th, 2012 at 01:17 PM
same, but the beam clamp is different.
So yeah the box itself is the same
71 notchback,
Membertelf
posted on February 9th, 2012 at 11:07 PM
Well i pulled the best 1 apart, i think withe some new bearings and seals it should be ok. fingers crossed.
Memberpsimitar
Threads: 148
posted on February 10th, 2012 at 01:39 AM
Had a look for ya and not even the big USa and UK vendors stock the worm drive anymore but so long as the gears aren't badly worn then it'll be fine. If they are worn then new bearings won't do a thing.
Membervlad01
Mood: Side ways
posted on February 10th, 2012 at 12:23 PM
There was a NOS type 3 steering box on ebay US a month or so ago. Was cheap around 250. I should of bought it:fakesniff:
there is this one though.
http://www.ebay.com.au/itm/Rebuilt-Volkwagen-Bug-Ghia-Thing-Type-3-German-Ste...
71 notchback,
Super ModeratorYogie
Threads: 108
posted on February 10th, 2012 at 02:36 PM
I know super beetle steering boxes are different for rhd than lhd. If the type 3 takes the same as the beetle then buying from the USA may not be a good idea if standard beetles are different too.
Yogie
posted on February 10th, 2012 at 09:11 PM
Same LHD and RHD
MemberSmiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
posted on February 11th, 2012 at 04:17 PM
With the beam front end the boxes are the same. It's the pittman arm that is different. So just =use your old pitman arm if you get a new box and it'll be fine.
Smiley :)
Membervlad01
Mood: Side ways
posted on February 11th, 2012 at 06:55 PM
Same LHD and RHD
:yes:
71 notchback,
Membertelf
posted on February 13th, 2012 at 08:31 PM
Well finally pulled the old box apart. Think it gone be ok, no pitting on the screw shaft where the bearings go and no play on the guide wheel. So after a good clean up i think its back together it goes and on to the car. Fingers crossed.
Membertelf
posted on February 14th, 2012 at 11:25 AM
Well i showed it to the engineer next to my work and he gave it the all clear. So now im wondering what grease to use when putting it back together.
posted on February 14th, 2012 at 04:05 PM
black molly
Membertelf
posted on February 14th, 2012 at 07:21 PM
What the hell is black molly?
MemberLucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
posted on February 14th, 2012 at 07:46 PM
Molybdenum Disuphide grease.
Also known as black grease.
Proper designation LLM grease from memory.
Membervlad01
Mood: Side ways
posted on February 14th, 2012 at 09:42 PM
^ correct.
Its a super ultra extreme pressure grease, but only for slow moving parts as it is super thick. Commonly used in the mining industry on their machine and earth moving vehicles. I recon its ideal for steering boxes.
I used some from work to do the poly bushes on my bomb. Dam good stuff.
Looks like metallic grey paste.
71 notchback,
Membercam070
posted on February 14th, 2012 at 09:48 PM
It's actually LMM. Castrol make some See http://www.castrol.com/castrol/multipleproductsection.do?categoryId=8000019&a...
Memberpsimitar
Threads: 148
posted on February 17th, 2012 at 05:48 AM
Huh, n I thought normal LM bearing grease is ok, by the Haynes manual.
[ Queries: 40 ] [ PHP: 3.6% - SQL: 96.4% ]
