| [ Total Views: 1534 | Total Replies: 15 | Thread Id: 95354 ] |
SebastienPeek
Threads: 89
| posted on February 14th, 2012 at 07:04 AM |
Engine & Carb Combo Question
Alrighty,
I have a 1600cc twin port motor. What are some well known good carb setups?
Should I stick with the dual carb root and get dual Webber 40 IDF's? Or do I go to a single Webber 40 IDF?
Do I not do Webber's and go back to a stock Solex single carb setup?
I'd like to get as much "bang for my buck" so to speak. I don't want to spend over a thousand dollars on just a carb setup, that's money I could
spend on the suspension that is definitely getting tired...
Any motor combinations that people have seen, had themselves or have heard of that work fine, that's what I want to know!
Any help would be great!
SebastienPeek
Threads: 89
| posted on February 14th, 2012 at 08:56 AM |
My main concern, are dual Webber 40 IDF's overkill for a stock 1600cc?
I can get dual 40's easy, it's just a matter of whether others have run them on a stock 1600cc or have had a good time with them.
As you're all probably aware by now, I haven't really had any good luck with the EMPI 34's (albeit I have them running a lot better now than
before).
What do you reckon?
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on February 14th, 2012 at 09:41 AM |
Are you wanting to increase the engine capacity at a later stage or will you be staying 1600cc ?
40's will work or a cheaper twin carb option would be kadrons
shokwave2
A.k.a.: Matt Hamilton
Threads: 28
| posted on February 14th, 2012 at 12:25 PM |
If you're after Kadron's, i may be selling mine a few weeks.
I run Kadron's on a stock 1600 and they gave it more 'oomph'. I was running a single 34 pict3 and it was just worn out and giving me intake leaks
at every seal. So i spoke to Rod Penrose and he sold me some Kadrons. I'm planning to upgrade in a few weeks to a bigger motor so i will be upgrading
my carbs too.
SebastienPeek
Threads: 89
| posted on February 14th, 2012 at 12:26 PM |
Craig,
have just sent you a PM asking about some 40's.
Shokwave2,
have sent you a PM as well.
Thanks!
Smiley
A.k.a.: Daniel Stephens
Threads: 110
Mood: Synchro'd
| posted on February 15th, 2012 at 11:17 PM |
I would recommend the Dual 40mm Kadrons too.
They are a set and forget carby. Once you get the adjustments right you don't have to touch them for a long time. Mine are working beautiful. And I
have a friend in Rocky that runs them on a stock 1600 in his super bug, it works great too.
Smiley
SebastienPeek
Threads: 89
| posted on February 15th, 2012 at 11:24 PM |
Smiley,
Already getting those kadrons, just have to wait till shokwave2 strips his motor down and then when they come in the post they'll go straight on and
I'll spend the day tunin them to get them perfect.
I'm also wondering what people think about the serpentine belt pulley kits that you can buy?
Do they improve the noise of the engine, like, do they quieten the engine a lot or what's the go?
Worth the money or not?
waveman1500
Also rides a Honda
| posted on February 16th, 2012 at 12:15 AM |
They're really just for looks. The standard V-belt is fine.
SebastienPeek
Threads: 89
| posted on February 16th, 2012 at 08:12 AM |
Thanks waveman1500, I figured they'd just be for looks.
Going to just get a new crankshaft pulley then, the one currently on is a little bent...
Bizarre
| posted on February 16th, 2012 at 10:34 AM |
buy a quality one and check it
I have seen several examples where the degree marks are not correctly aligned
SebastienPeek
Threads: 89
| posted on February 16th, 2012 at 03:04 PM |
Agreed Bizarre.
I don't want one that is poor quality and will fall off or anything like that while I'm driving.
I'm thinking a Jaycee billet one from vwparts.net or if they are sold anywhere here in Australia, then from there.
Joel
| posted on February 16th, 2012 at 08:37 PM |
posted by waveman1500
V-belt is fine yes but rib belts run alot smoother which is why modern cars all run them.
on a type1 engine that reduces alot of tinware rattles, noise and vibration.
A friend fitted one to his bug, I was surprised how much quieter and smoother it idled.
THe downside is they don't slip which on a high revving motor can lead to the fan go kablamo.
Craig Torrens
Threads: 347
| posted on February 16th, 2012 at 09:37 PM |
Most V belt kits I've seen have an aluminium generator pulley, these will flog out at the K way over time.
SebastienPeek
Threads: 89
| posted on February 17th, 2012 at 01:27 AM |
So, no to a serpentine belt pulley system and yes to a Jaycee billet crank pulley?
I guess I won't be revving the crap out of the engine, but every now and then I'd want to go for a little bit of a blip.
Could I get away with just the serpentine belt system? She's just my daily, and it isn't like I'll be racing her or dragging her. Not with a stock
1600 anyway...
I'm thinking smooth idle and quieter idle makes for a few good positives that's for sure...
I've seen them on quite a few bugs (even drag ones), so I'm sure they're not that bad that they'll make the fan go kaboom?
vwo60
Threads: 71
Mood: good
| posted on February 17th, 2012 at 06:50 AM |
On two of my cars i run a saco aluminium top pulley and they have been on there for a few years now with no problems, you will only have problems if
they do not fit the shaft correctly or the nut is not done up tight, i had to heat mine up to fit them as they had a interference on the shaft.
DubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
| posted on March 13th, 2012 at 11:47 AM |
posted by SebastienPeek
Smiley,
How did you get on with those carbs? Was there a noticeable improvement? I am thinking of the same setup but any info is good info. Cheers
