| [ Total Views: 1820 | Total Replies: 10 | Thread Id: 95461 ] |
cam070
| posted on February 20th, 2012 at 06:01 PM |
Nylon Washers for Heater Control Lever
Just wondering if anyone knows where I can source the nylon washers for the heater control levers.
I know the likes of RS Components sell them, but you can only get them in boxes of 50, which is about 46 more than i need.
FYI, this is the type of thing I need, but just the washers:
Heater lever control kit
pod
A.k.a.: paul mrvw061
Mood: could be better
| posted on February 20th, 2012 at 07:15 PM |
whats the inner and outside size ? as we use some nylon washers at work ,but only in limited sizes
cam070
| posted on February 20th, 2012 at 07:35 PM |
Hi pod. I'D is 8mm. OD is 27mm but the OD is not critical. Cheers cam
1303Steve
| posted on February 20th, 2012 at 10:06 PM |
If you cant find any you could make some with some flat sheet and a hole saw.
pod
| posted on February 21st, 2012 at 03:52 PM |
ok cam will have a look to see what we have
pod
| posted on February 22nd, 2012 at 03:51 PM |
didnt have any that size so made you some out of black delrin in the lathe ..pm me your address and i put them in the post for you,and was it 2 or 4
you need?
cam070
| posted on February 22nd, 2012 at 05:37 PM |
posted by pod
you need?
What a CHAMPION! Thanks a million Pod. PM sent!
BTW I needed 4.
Cam
pod
| posted on February 22nd, 2012 at 07:24 PM |
no pm as yet
cam070
| posted on February 22nd, 2012 at 09:11 PM |
Ok pm'ed again. Replied to yours
pod
| posted on February 22nd, 2012 at 10:14 PM |
got pm back so will pop in the post tomorrow
cam070
| posted on February 24th, 2012 at 11:17 PM |
Again Pod, thanks for coming to the aid of my resto. Here are some pics:
The old and mostly has it factory washers with the custom machines Delrin washers from Pod.
Assembly stage with cleaned/painted components. Washers are a perfect fit.
And all assembled, just needing final adjustment down the track
In case anyone was wondering what Delrin was. It's a DuPont product, tradename for Acetal. Properties from their site are:
"Delrin® acetal resin bridges the gap between metals and ordinary plastics with a unique combination of creep resistance, strength, stiffness,
hardness, dimensional stability, toughness, fatigue resistance, solvent and fuel resistance, abrasion resistance, low wear and low friction."
Sounds perfect for the job.
| Error |
| Error |
| Error |
