[ Total Views: 1124 | Total Replies: 3 | Thread Id: 95787 ]
Author: Subject:  New here.Have some questions.
Memberiwantbus
Threads: 1
posted on March 12th, 2012 at 03:15 AM
Hello everyone,
I have been lurking here for a while now and actually go the idea
for my subaru motor from here. I have a 74 vw bus campmobile that has a 2.5l DOHC motor in it. I have a couple questions that hopefully someone can help me out with so I can get it running.
I mounted the radiator under the bus(belly mounted) it is a radiator with no CAP.
My question is,
What is the best way to run my cooling system?
Do I need an expansion tank ?
Can I just use and an inline cap and call it a day?
Really looking forward to someone helping me get my cooling system together. Thanks in advance.
I have searched and read too, but I am asking because it is still not very clear to me.
Thank you.
posted on March 13th, 2012 at 02:48 PM
Originally posted by iwantbus
Hello everyone,
My question is,
Do I need an expansion tank ? YES
Can I just use and an inline cap and call it a day? MAYBE, SUBJECT TO A WHOLE LOT OF VARIABLES, BUT AN EXPANTION TANK WILL WORK BETTER.
Thank you.
If you tell us where you are and the like we could probably send you to someone who might help.
Membertweety
Threads: 68
posted on March 13th, 2012 at 07:51 PM
If you have a radiator with no cap then it should have a exit tube for an expansion tank. I used a Hyundai i30 diesel expansion tank. cost around $70. It has the 5 8th inch inlet, comes with cap and there are two small tubes sticking out of the bottom and top side. I've connected these two tubes with transperant hose. Even though the tank is suppose to be transperant its more translucent, hard to see the level so this tube allows me to clearly sight the green fluid level.
Works a treat and improtantly no air in the system. My new Alfa radiator has a similar tube that I attached a brass tap to so it assists in the bleeding process when refilling the system.
http://i804.photobucket.com/albums/yy330/eaglefree/IMG_0005-5.jpg
The pic below shows the tank. The fuel hose on the RHS is now a cler view hose showing the water level.
http://i804.photobucket.com/albums/yy330/eaglefree/IMG_0006-3.jpg
http://i804.photobucket.com/albums/yy330/eaglefree/IMG_0034.jpg
http://www.youtube.com/watch?v=HXwh4z8d66o
SUBARU ea81, VW auto, Detour camper
My ex girlfriend said "its me or a trike". Her big mistake.
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on March 13th, 2012 at 08:33 PM
Have a look at my build, link from the bottom of my post in the sig line
[ Queries: 40 ] [ PHP: 11.6% - SQL: 88.4% ]
