| [ Total Views: 1456 | Total Replies: 16 | Thread Id: 96471 ] |
coletrickle
Threads: 34
| posted on April 18th, 2012 at 07:03 PM |
F/S 13 sec engine and gearbox package
2332cc 94x84 scat crank,scat h beam rods, Vw heads by matt berry/Peter herriman, berg 310 cam, eaton lifters(molybdenum wet lube coating) cb dual
springs, cro mo push rods, scat 1.4 rockers,deep sump, full flow with phenix braided lines,48 Spanish IDA's on tall matched porter manifolds, k+n
filters berg linkage with berg 1/2 adjusters,ceramic coated pistons with molybdenum skirt coating 9.7-1 compression,barrels have been coated with
thermal dispersant,Vintage Speed full comp exhaust 44mm,010 dizzy, dog house cooling system with all tin wear,motor has aprox 15000 km since freshen
up.
Ace 30 oil and services every1500 klm.
Gear box is a Late 1300 swinger by Dave Buttler stock late 1st and 2nd 1.49 3rd 1.125 4th with 4.12 cwp Crown super diff.All gear box internals
except cw and pinnion coated with molybdenum wettable coating including fulcrum plates SAW axles( the old USA ones)t3 brakes berg style mid mount.
Basically bolt this drive train in any bug and you will have a mid to low 13 sec street bug allways have run vpower or bp ultimate dosen't run hot
or leak oil!
$10,000. I'm happy to answer any questions thanks for looking .Col
1916baja
Threads: 176
| posted on April 18th, 2012 at 07:28 PM |
What the hell col? Why are you parting with this super reliable combo?
tar76
Threads: 95
| posted on April 18th, 2012 at 07:49 PM |
Sad to see this going Col......Bullet proof package tho
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
matberry
| posted on April 18th, 2012 at 07:50 PM |
WOW. A good deal for anyone. So you were serious. Good luck with the sale mate.
You better edit, your crank is 84mm
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on April 18th, 2012 at 08:29 PM |
Is this the motor you ran at WSID for the VW Drags ?
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on April 18th, 2012 at 08:32 PM |
word on the street is ,he is buying a crysler neon!!!!!!
1916baja
Threads: 176
| posted on April 18th, 2012 at 08:41 PM |
I think you'll find it is Craig, he was babying it that day though.. i think he ran a few mid 13sec passes in it at jamboree. Fair enough... neons
are cool as
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on April 18th, 2012 at 08:46 PM |
matberry
| posted on April 18th, 2012 at 08:49 PM |
posted by whathaveidone
   Oh so true
Stanley
Threads: 270
| posted on April 18th, 2012 at 08:51 PM |
I heard he was doing a suby conversion......
whathaveidone
Threads: 98
| posted on April 18th, 2012 at 08:53 PM |
4WD too!!!!
coletrickle
Threads: 34
| posted on April 18th, 2012 at 09:04 PM |
posted by Craig Torrens
Yes Craig it's the engine I ran at the Sydney Vw event,Sydney jambo etc. Sorry it's an 84 mm as matty said, it's run 13.41 @97 in a stock
suspension bug on real radials.
matberry
| posted on April 18th, 2012 at 09:06 PM |
Also ran 13.0 @ 104 (?) with FK 87 and M/T radials
coletrickle
Threads: 34
| posted on April 18th, 2012 at 09:13 PM |
posted by Stanley
I'm doing a valiant conversion!
coletrickle
Threads: 34
| posted on April 18th, 2012 at 09:24 PM |
Ben your pretty close one of the engines I'm looking at came out of a neon! A NHRA pro stocker!500ci 1360 hp! Still all motor!
Stanley
Threads: 270
| posted on April 18th, 2012 at 09:26 PM |
So your busy making a set of wheelie bars from shopping trolley wheels
h
| posted on April 18th, 2012 at 09:44 PM |
