[ Total Views: 713 | Total Replies: 2 | Thread Id: 96911 ]
Author: Subject:  Beetle Chassis + Body lineup
MemberDubLeg
A.k.a.: Lewis Templar
Threads: 46
Theme: UltimaBB Psyche Red
posted on May 15th, 2012 at 02:35 AM
We all know you can lift and change the bodies on beetles. Is there any limit to what years you can change it up?
Can I change a pre '67 body with a post '67 body?
VollyWaffle
posted on May 15th, 2012 at 07:47 AM
yes they will all fit except for Strut bugs 71 to 75
MemberSides
A.k.a.: Dave Sidery
posted on May 15th, 2012 at 11:41 AM
As Dave says above they'll all fit other than strut bugs - pretty common to put a later IRS pan under an early body.
One thing tho is that upto 67 and 68-on are different around at the body mount at the rear shock towers - the hole will line up, but you'll need to raft the bracket on the body either higher or lower depending on the combo.
My toys
