[ Total Views: 1961 | Total Replies: 10 | Thread Id: 96936 ]
Author: Subject:  Front seats rusted in place - ideas?
Memberhowjow
Threads: 8
posted on May 15th, 2012 at 10:04 PM
Maybe a stupid question, but my front seats don't move at all and seem to have seized up or somewhat rusted in place. Any ideas how I get them out or get them to move? Thanks
Membergrumble
Mood: happy all the time
posted on May 16th, 2012 at 05:55 PM
spray the tracks with Inox,WD40 or similar,get someone in the seat holding the release and jump in behind,put both feet on the seat bracket and push,if this doesn't work give the tracks a few whacks with a hammer and repeat.
MemberLUFTMEISTER
Threads: 119
posted on May 16th, 2012 at 06:53 PM
Check that it has not been welded in place if the retaining latch broke.
Member1916baja
Threads: 176
posted on May 16th, 2012 at 07:08 PM
If the seat slides forward but will not slide all the way off, there is a tab you need to push in or pull out near the front of the outside runner.
http://i432.photobucket.com/albums/qq43/1916baja/BigAssWing22.jpg
posted on May 16th, 2012 at 08:32 PM
yep the TAB is to be checked in 68 n later cars on outside on bugs n inside on type 3s
but get a mate to sit in back seat while you lift adjuster and kick the seat runner forward
never had one i couldnt get out with some FOOT power :!::!::blush:
Memberwaveman1500
Also rides a Honda
posted on May 17th, 2012 at 12:46 AM
If you have the later seat runners with the plastic sleeves on them, I found that it helps if you pull the plastic bits rearwards as far as possible before trying to push the seat forwards. Sometimes the plastic bits can get jammed up in the rails and stop the seat. Otherwise, as others have said, just get in the back seat and push with your feet!
posted on May 17th, 2012 at 08:38 PM
What model car are we talking?
Beetles used a few different style runners over the years and theres alot of different VW models ;)
Memberwaveman1500
Also rides a Honda
posted on May 17th, 2012 at 11:34 PM
Joel, you know that we all assume that it's a Beetle because this is predominantly an aircooled forum! Also, I can't imagine a Golf with seized seat runners.
posted on May 18th, 2012 at 09:41 AM
Well this is true, although Mk1 and I think Mk2 Golf use the same bastard runners as 74 on Bugs.
Memberhowjow
Threads: 8
posted on May 18th, 2012 at 07:40 PM
Thanks guys. The old get in the back and kick while my mate sat in the front with the lever turned worked a treat! Who would've ever thought?
posted on May 18th, 2012 at 08:59 PM
see it WORKED
[ Queries: 40 ] [ PHP: 25.0% - SQL: 75.0% ]
