[ Total Views: 762 | Total Replies: 11 | Thread Id: 96937 ] |
BrisDubba
Threads: 190
posted on May 16th, 2012 at 12:40 AM |
Removal of IRS arms - stubborn bolt.
Am trying to remove the IRS swing arms but the bolt seems a tad stubborn. Is there a specific tool for the job or do I just need a bigger one for more
leverage. I am using an 18mm(or 19 cant remember) bolt with welded on nut, which fits well just wont budge it. I tried it with a lit bit of heat also
without any luck.
Any suggestions ?
Peter
VW Toys
64 Beetle - club car - Herbie
RSK 718 Porsche Spyder
76 Southern Cross Offroad racing buggy. "Manx Buggies"
77 Cobra Offroad racing buggy "RipOff"
68 Country Buggy KO200
64 Manx swb
70 Dual Cab kombi
74 Dual Cab kombi
74 Micro bus
matberry
posted on May 16th, 2012 at 08:23 AM |
mmmm, try harder....maybe purchase a 17mm allen tool, I have one which is 1/2" drive, stick a breaker bar on there and bam...it's gone.... Make your own version by welding your 17mm bolt to some flat bar/pipe or
whatever, to get a long lever happening.....
Around the perimeter of the bolt there are 3 grooves that the rim gets punched into as a lock for the bolt, sometimes a little impact on this edge
with a knockometer will help unfreeze the bolt.
Aussie Dubbin
Threads: 90
posted on May 16th, 2012 at 08:33 AM |
17mm allen tool is a cheap and worthwhile investment. As Matt said, more leverage, once you 'crack' the tension seal you will remove it a lot
easier.
1303Steve
Threads: 559
posted on May 16th, 2012 at 01:21 PM |
As Matt said get the 17 mm with 1/2 drive, they also fit the transmission fill & drain plugs.
Once you get it loose they take quiet a few turns to get them out, I use a section of 17 mm allen key with a ratchet ring spanner.
Your going to be using a lot force, make sure that the car wont fall off the stands.
Error |
SuperOwen
Threads: 67
posted on May 16th, 2012 at 08:54 PM |
I had one recently that was really stubborn. Ended up finally cracking with a 4-5ft long pipe as a lever, not sure what I would have done without a
hoist!
68AutoBug
posted on May 16th, 2012 at 09:10 PM |
Quote: | Originally
posted by matberry
Where do You get those knockometers from mat??
looked on ebay but none for sale...
My Son, a few years ago, had a problem with one of those coming loose all the time...
replaced the bushes... I'll bet He didn't crimp the outer lip..??
probably because He couldn't find a knockometer at the time
matberry
posted on May 16th, 2012 at 09:24 PM |
mmm, not on ebay eh. That's odd, I guess a specialised tool shop would have one.
BrisDubba
Threads: 190
posted on May 19th, 2012 at 08:34 PM |
success...
Well am pleased to advise that those stubborn little bastards didnt win today - I fuelled up on weetbix and found my 17mm allen key tool that I had
bought from Micks a few years back. A quick trip down to repco to add to my breaker bar range, and then hopped into it. They certainly put up a fight
- right to the end - I reckon it took about 30 minutes of solid work to get them out -good thing I dont have to do that everyday..
Thanks for the advice
Peter
VW Toys
64 Manx swb
70 Dual Cab kombi
74 Dual Cab kombi
74 Micro bus
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
posted on May 19th, 2012 at 09:37 PM |
Quote: | sometimes a little
impact on this edge with a knockometer will help unfreeze the bolt.
Otherwise known as a BFH.
matberry
posted on May 19th, 2012 at 09:40 PM |
mmmm, funny, up here thier other name is FBH.........
Lucky Phil
Threads: 16
posted on May 19th, 2012 at 10:56 PM |
Must be a regional thing!
vlad01
Mood: Side ways
posted on May 28th, 2012 at 03:59 PM |
nothing a little bit (meaning a lot!) of C4 won't fix.
71 notchback,
