[ Total Views: 767 | Total Replies: 1 | Thread Id: 97406 ]
Author: Subject:  wasser boxer
Memberbugzla
Threads: 240
Mood: always happy
posted on June 13th, 2012 at 11:40 PM
wasser boxer
is it possible to run a wasser boxer just for drag use without water or do i go into the expence of converting it to aircooled and if so who does the stud conversion here in australia and other machining needed
stevo
MemberSuperOwen
Threads: 67
posted on June 14th, 2012 at 12:12 AM
Any competent engineering shop can change the head stud pattern, although I'm 99% sure stock wbx pattern is the same as 4inch bore pauter autocraft etc, which may be a better option for a drag engine? I think you'll also have to remachine the case barrel spigots to take whatever barrel you end up using.
[ Queries: 40 ] [ PHP: 3.1% - SQL: 96.9% ]
